Forum topic by shipwright | posted 01-29-2022 01:04 AM | 424 views | 0 times favorited | 8 replies | ![]() |
A friend is in need of the reeves drive pulley (lathe side) for his Delta 46-715 lathe. Like so many Delta parts it seems not to exist anymore. However there are sometimes similar workable parts or other work arounds. -- Paul M ..............the early bird may get the worm but it’s the second mouse that gets the cheese! http://thecanadianschooloffrenchmarquetry.com/ |
8 replies so far
#1 posted 01-29-2022 01:12 AM |
Have they looked on ebay? That’s my best guess. |
#2 posted 01-29-2022 01:49 AM |
Have you tried ereplacementparts.com? They seem to be the only place online that might have older Delta parts. -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#3 posted 01-29-2022 09:17 AM |
Maybe something too expensive, but this is how I solved it (BTW Not a Delta) |
#4 posted 01-29-2022 03:45 PM |
Thanks for the thoughts. -- Paul M ..............the early bird may get the worm but it’s the second mouse that gets the cheese! http://thecanadianschooloffrenchmarquetry.com/ |
#5 posted 01-29-2022 03:59 PM |
Do you have a photos of the pulley needed and the bore and keyway size? cheers, Jim -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! Variety is the Spice of Life!! |
#6 posted 01-29-2022 04:56 PM |
Because so many people have had failures on the pulleys for this model I decided to look elsewhere for a solution. There is a good series of articles by Sawdustonmyshoulder on this site. I’m taking a slightly different tack and going with a solution on dazecars.com. Yup, it’s a car restoration site, but the principal did a similar conversion from an AC motor to a DC motor (from a treadmill) that yielded a variable speed solution and cost less than what replacing the reeves drive pulleys would cost. If your friend is dead set on sticking with reeves drives, there is a pulley supplier in the Carolinas who claims he can supply a complete set of reeves pulleys that fit the 46-715. He wants something like $170 for the set. I got his name from Delta Customer Support when I asked if they knew of anyone who could supply the pulleys. I believe the company name began with L but not sure. I discarded that solution because my lathe never operated well with the Reeves drives (a lot of force required to change speeds), and there were some shortcomings to his solution. Am currently in the process of converting my 46-715 to the treadmill motor right now. I’m having trouble acquiring pulleys that fit the metric shafts of the lathe (25mm) and the motor (17.5mm) and will allow me to use a standard type A V-Belt (really want to use a link belt.) I’m closing in on finding the needed pulleys, however. |
#7 posted 01-29-2022 05:35 PM |
Since Reeves drives are kind of specialized, they’re usually outsourced parts, so if you google “reeves drive pulley” and pick through the results, you might find one with the same dimensions. They’re very common in variable speed drill presses. -- Unix programmers never die; they just > /dev/null |
#8 posted 01-29-2022 06:00 PM |
A DC motor, great idea! About the pullys: Do it the Matthias Wandel way, out of Baltic Birch plywood, |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2077 |
Finishing
6714 |
8187 |
34189 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9902 |
