Forum topic by Carol | posted 01-27-2022 10:24 PM | 393 views | 0 times favorited | 5 replies | ![]() |
Topic tags/keywords: sketchup i’ve been honing my sketchup skills, designing pieces and creating cut lists and diagrams but after watching another hour of videos, still can’t figure out how to create a cutting diagram for dimensional lumber or what sketchup calls “solid wood”. can i get a cutting diagram for dimensional lumber? can anyone point me to a learning source? it’s pretty cool that i can get a cutting diagram for plywood. until i finally figured it out, i’d spend hours arranging and re-arranging parts on a 4×8, doing the same thing sketchup does in seconds… -- Carol |
5 replies so far
#1 posted 01-28-2022 01:18 AM |
I believe that is probably one of the features you get if you pay for SketchUp. I’m happy to be able to make scenes of the various parts and their dimensions that I can use to make printable pdf files. Honestly, I don’t use cutting diagrams. After a while you get proficient at figuring out how to make the best of the boards you have. -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#2 posted 01-28-2022 02:43 AM |
Cut List 4.1 is an add-in or extention that I have used but only on the 2017 version so I don’t know which other versions it works with. There may be a newer version available for later versions of Sketchup. If I remember correctly, if you do nothing it automatically assumes that the parts are for dimensional lumber. If you put one of the keywords for sheet goods (e.g.;sheet, plywood, MDF—you can add your own keywords to the list) into the component name (I usually put the keyword into parenthesis) it will put it onto a standard 4×8’ sheet. This is handy but does not always do the most efficient layout. If I do not like the layout, I typically draw 4×8 rectangles and then drag a copy of each component over to the the rectangle and lay it down so that I can play around with different layouts. The manual method may not be great for complex drawings with lots of parts because it is easy to miss one or more. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#3 posted 01-28-2022 02:56 AM |
I can confirm Lazyman’s memory regarding how cutlist works is accurate. One addition is that cutlist also checks the name of the assigned material for each part and it’s easier to apply custom materials to parts than rename components to have keywords. We do use the cutlist plugin to generate an order list but not for cutting diagrams on solid lumber since we get random width, random length material. If you’re using s4s then cutlist may be more useful to you. The other disadvantage to relying on cutlist for solid boards is that the software cannot do grain matching. The easy way to process a stack of boards without using software is start by marking out the longest or widest parts directly on the wood and move down the list to smaller parts until you’ve got everything accounted for. With this method, we can process 500bf quickly and end up with very little waste. -- See my work at http://altaredesign.com |
#4 posted 01-28-2022 03:13 AM |
thanks for the help all. actually, once the lightbulb went on and i dropped my forehead on the keyboard – is such a simple solution… just adjust the size of sketchup’s sheet goods to whatever size lumber i’m using. instead of a 4×8 sheet, for this particular project, i have 1×6s and 1×10s. -- Carol |
#5 posted 01-28-2022 09:32 AM |
Cutlist can “calculate” for you the board feet you may require for purchasing, however, I find an accurate cutting diagram is a manual effort… If I make up a cutting diagram, I usually just do it for the laser, however, there is no reason why you can’t draw a bounding box representing your board/sheet and overlay that with your components (see last picture). I use this method extensively for laser cutting layout… though I will admit I have the Pro version that I pass through Layout to “PDF” it to CorelDraw for sending to my laser. Here is the the latest project I’m working on, 6mm MDF, The 3D perspective is retained for all components included in the diagram, Without Layout, you can still dimension in Sketchup... here is a KISS layout of the 6mm… Though if needed, I would normally do in Layout. Just use Top view, Parallel Projection. -- If your first cut is too short... Take the second cut from the longer end... LBD |
Forum | Topics |
Woodworking Skill Share
13543 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6712 |
8187 |
34181 |
CNC Woodworking
384 |
Hand Tools
6769 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5577 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9900 |
