Forum topic by willhime | posted 01-27-2022 08:29 AM | 862 views | 0 times favorited | 21 replies | ![]() |
Topic tags/keywords: resource jig tip question trick joining shaping milling router I’m wanting to cut a dado right on the seam of a mitered corner on a box. The only thing I can think of is making a jig that holds the router at 45 degrees and slides down the corner edge. Maybe with a clamped on fence to stop the router from falling. I hope someone here has a better solution. -- Burn your fire for no witness |
21 replies so far
#1 posted 01-27-2022 09:00 AM |
If I wanted to make that joint, would cut 1/2 groove width in each side of miter, BEFORE assembly. Would be simple to use same 45° blade angle and lower blade to make a partial depth cut. Use piece of wood against the fence to move the board out 1/2 width of insert, and adjust the fence once. To cut that spline after assembly, would build a spline jig that is rotated from normal and clamps on a cross cut sled. PS – Would be worried using router bit to cut groove in center of a miter joint. The rotation of bit would be always be pushing chips outward, attempting to open the joint. If you encounter a crack or imperfect grain direction creating a large chunk, could blow the joint apart with disastrous outcome. Using a table saw blade seems safer, as it pulls chips down and out of groove with minimal side stress. As always, YMMV and Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#2 posted 01-27-2022 09:26 AM |
I would try using my dado blade on the table saw turned to 45 degrees. |
#3 posted 01-27-2022 02:13 PM |
when i got my kehoe jig they include a jig called the corner inlayer…this will do exactly what you are describing….maybe you can find someone who has this jig…i’ve had mine 20 yrs. so its not something new…good luck!!!! |
#4 posted 01-27-2022 02:25 PM |
My thought, too. -- Everything is a prototype thats why its one of a kind!! |
#5 posted 01-27-2022 03:35 PM |
The OP doesn’t say how big the box is, but if it is small enough to handle on the table saw, I agree. However, I think that rather than make a groove at 45 deg, I would cut a rabbet (sides 90 deg to box faces). And, then glue in a triangular decorative piece (or square and shave the 45 after gllue-up). This way, it would be easier to cut and there would be less chance of tear-out. Also, it could be easily cut with a router. |
#6 posted 01-27-2022 04:19 PM |
Make a jig similar to a spline cutting jig, just run it in the other direction. Use an up-cut spiral bit with sacrificial boards in front and behind. |
#7 posted 01-27-2022 07:36 PM |
OK funny story, I usually don’t share how stupid I can be but this was so long ago I think I can. So, being the inventor kind of guy I am, a figured out a solution to do the same cut above, it was so simple, I couldn’t believe it wasn’t already being done. |
#8 posted 01-27-2022 09:35 PM |
A different approach I’ve used to accomplish the same effect. Don’t know how to post a picture but I recently made a six-sided pot pourrie(sp?) box using this technique and the inlays appear to be solid corner inlays. It’s a time consuming process, but in my opinion, worth the time spent. Good luck with your project, |
#9 posted 01-27-2022 10:31 PM |
I’m missing something. That is way more complex and difficult than it needs to be. Why are you cutting a 45 deg dado rather than a simple rabbet that can be simply cut with a rabbeting bit with a bearing guide? Or, if the box is small enough to handle, it can be done on the table saw. See #5 above. |
#10 posted 01-28-2022 05:02 AM |
rabbet the corner tablesaw/router. (I use the router table) end up with bilyo’s picture. |
#11 posted 01-28-2022 11:53 AM |
Bilyo has got it. -- Everything is a prototype thats why its one of a kind!! |
#12 posted 01-28-2022 01:26 PM |
Thanks for sharing LRM. It is always nice to to see that people smarter than me also have DA moments. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#13 posted 01-28-2022 03:18 PM |
Thanks, that’s not the only one, I could write a book on my DA moments…. |
#14 posted 01-28-2022 04:07 PM |
Sorry. Because I never have those ;>) and don’t understand them ;>) I missed the humor. Good one. |
#15 posted 01-28-2022 05:54 PM |
This worked well for me on the table saw when making some hexagon tubes for a kaleidoscope. I made mine a lot deeper because I turned the center part of the shaft round on the lathe so the spline had to go below the round finished diameter. -- Les B, Oregon |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2077 |
Finishing
6714 |
8187 |
34189 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9902 |
