Forum topic by Novum | posted 01-26-2022 05:08 PM | 240 views | 0 times favorited | 5 replies | ![]() |
I have a 30+ year old bench grinder that needs a new wheel so I can sharpen lathe chisels. The current wheel to replace is a 7” x 1” x1/2” arbor. I guess I need about a 60-80 grit? Can’t find that size anywhere. Sources? Thanks |
5 replies so far
#1 posted 01-26-2022 05:33 PM |
I think you’ll have to go with a 6” wheel. The only wheels I know of that come in a standard 7” diameter are surface grinder wheels and they have much larger arbors. 6” bench grinders have 1/2” arbors. If your grinder is big enough, you could use an 8” wheel and use a reducer bushing to fit it to the smaller arbor. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#2 posted 01-26-2022 05:43 PM |
One other note, if you are only going to be sharpening chisels, and not any heavy grinding or reshaping, etc. I would go with the fine grit. I have a 120 grit on my grinder and I like it. I have also read that the white stones generate less heat which can be a good thing, but they do wear down faster. |
#3 posted 01-26-2022 05:47 PM |
Thank you. Since it is a two wheeler I will leave the other for mower blades and such. I assume there is not problem with 7” on one side and 6” on the other? |
#4 posted 01-26-2022 05:50 PM |
Probably not. Provided both wheels are fairly balanced independently you probably won’t notice any appreciable increase in vibration. It’s not different than having a wire wheel on one side and grinding wheel on the other which is how a lot of manufacturers sell new grinders. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#5 posted 01-26-2022 05:58 PM |
I agree with the finer grit and white wheel recommendations. For mower blades and the like I find my angle grinder works much better and easier. I use the cordless Dewalt and I can even sharpen them on the mower…..especially the brush hog mower on my tractor with 1/2” thick blades. -- Les B, Oregon |
Forum | Topics |
Woodworking Skill Share
13540 |
Woodturning
3007 |
Woodcarving
617 |
Scrollsawing
436 |
Joinery
2073 |
Finishing
6705 |
8186 |
34172 |
CNC Woodworking
384 |
Hand Tools
6768 |
Jigs & Fixtures
1920 |
Wood & Lumber
7611 |
1696 |
Focus on the Workspace
2748 |
1295 |
Woodworking Trade & Swap
5574 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9897 |
