Paint inside small holes?
Forum topic by SawdustTX posted 01-24-2022 03:42 PM 415 views 0 times favorited 23 replies Add to Favorites Watch
View SawdustTX's profile
SawdustTX
414 posts in 3782 days
01-24-2022 03:42 PM
Topic tags/keywords: paint painting small holes painting holes flat black stage props stage furniture
As usual, finishing is the hard part of every project.
Making stage prop stands, so everything gets a flat black finish.
Thought I could get away with not painting the insides of the mounting holes and slots. I was wrong. They really show especially when light hits them.
Holes are 3/16”
Slots are 1/4”
These are quick and dirty stands, not fine furniture, so my criteria are:
1. No spraying, needs to be some kind of hand painting
2. I’m not repainting the faces so whatever I do has to only cover inside the holes
3. the inside of the holes/slots are relatively smooth, but some sharp edges. Tried a Q-tip, it just gets shredded
4. I am not sanding the insides of all those slots. :)
4. has to be quick, like an hour max to do all 80+ holes and slots
Anyone have a brilliant idea how to accomplish this? May just have to live with it?
Thanks LJ’s!
-Steve
-- Make it your ambition to lead a quiet life, to mind your own business and to work with your hands. 1Thessolonians4:11
23 replies so far
View hotbyte's profile
hotbyte
1156 posts in 4433 days
#1 posted 01-24-2022 03:53 PM
Small artist brush from a hobby store.
SawdustTX
#2 posted 01-24-2022 04:01 PM
- hotbyte
I think that will take forever? I’m trying to think of something I can dip in paint, drag down the slot, done. Feel like an artist brush is so small it doesn’t hold much paint and will have to be dipped every 1/2”? I’ll try it, thanks!
View controlfreak's profile
controlfreak
3737 posts in 1059 days
#3 posted 01-24-2022 04:03 PM
Hunter Biden and a straw.
View SMP's profile
SMP
5308 posts in 1363 days
#4 posted 01-24-2022 04:04 PM
I can’t really tell how big the holes are but i have used those small foam rollers(like for touch ups) to do stuff like that. They hold a bunch of paint and they squish to fit into holes smaller than them.
View Knockonit's profile
Knockonit
1235 posts in 1660 days
#5 posted 01-24-2022 04:16 PM
qtip and lots of them, and second hunter and straw, funny stuff
Rj in az
-- Living the dream
controlfreak
#6 posted 01-24-2022 04:22 PM
The 3/16” holes and maybe the slots too, You may do well with pipe cleaners. They may act like little round paint pads. They should both hold paint and deposit it on the desired surface.
SawdustTX
#7 posted 01-24-2022 04:22 PM
- SMP
they don’t fit. Holes are 3/16, slots are 1/4” :(
View Chenier's profile
Chenier
74 posts in 1165 days
#8 posted 01-24-2022 04:23 PM
Haven’t done this, but it’s the first thing I’d try: cut a sliver off a foam paintbrush and mount it on the end of a Q-Tip with the tip cut off using 5-minute epoxy.
Edit: Pipe cleaners! Brilliant.
SawdustTX
#9 posted 01-24-2022 04:23 PM
Rj in az
- Knockonit
per my post, tried that. :( The q-tip shreds immediately and leaves paint soaked cotton blobs in the holes/slots.
SawdustTX
#10 posted 01-24-2022 04:25 PM
- controlfreak
I feel like this might work! Now where does one buy pipe cleaners? thanks!
View splintergroup's profile
splintergroup
6945 posts in 2680 days
#11 posted 01-24-2022 04:26 PM
You can get nylon spiral wound pipe/engine oil passage bristle brushes in a wide range of diameters.
I think even Harbor Freight sells these sets.
controlfreak
#12 posted 01-24-2022 04:28 PM
- SawdustTX
I got to thinking about this as pipe smoking has gone away mostly but Hobby Lobby or Amazon should have them.
View DS's profile
DS
4108 posts in 3878 days
#13 posted 01-24-2022 04:28 PM
Haven t done this, but it s the first thing I d try: cut a sliver off a foam paintbrush and mount it on the end of a Q-Tip with the tip cut off using 5-minute epoxy.
- Chenier
+1
I would be making a tiny foam brush by attaching a cut off portion to the stem of a Q-tip.
-- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS
View JCamp's profile
JCamp
1740 posts in 2008 days
#14 posted 01-24-2022 04:43 PM
Spray paint with one of those little straw things that come on WD40 cans? Small paint gun, like ones used on little toy cars. Or put a blob of paint down in it then use a tooth pick or something like that to slush it around and coat the inside
Or screw the paint and use dye or something like that.
-- Whatsoever thy hand findeth to do, do it with all thy might
SawdustTX
#15 posted 01-24-2022 04:43 PM
- splintergroup
I have these for cleaning my spray guns, off to try this now.
