Forum topic by ric350 | posted 01-24-2022 12:36 AM | 456 views | 0 times favorited | 8 replies | ![]() |
Topic tags/keywords: question Where can I find an adaptor to connect my WEN 6524 Oscillating Belt and Spindle Sander to my RIDGID 16 Gal. 6.5-Peak HP NXT Wet/Dry Shop Vacuum? |
8 replies so far
#1 posted 01-24-2022 03:32 AM |
Do you happen to know anyone with a 3D printer? That’s an easy print. -- Joe | Spartanburg, SC |
#2 posted 01-24-2022 10:45 AM |
Take a look at woodworkers supply, a few years back these fittings were sold as a set, and I’ve kept them in the miscellaneous fittings box in the high storage. They’re tapered, so they generally can press fit or a few wraps of tape can adjust to make the connections work. I use the 1 1/4” one to connect my Clayton spindle sander to the DC system. WW Supply has awesome customer service if you have any questions, plus easy returns. -- I've decided 1 mistake is really 2 opportunities to learn.. learn how to fix it... and learn how to not repeat it |
#3 posted 01-25-2022 02:49 AM |
You can make adapters for anything to anything using a plastic bottle (like a bottle of water from the store) and a heat gun. Empty the bottle, cut the ends off, slip the tube over the larger item, heat. Slide the other end over the other fitting, heat. Easy peasy. If wanted wrap with cloth tape to reinforce. |
#4 posted 01-25-2022 05:07 AM |
I had that problem and found a hose kit that had two different size connections at HD that fit the need. It also came with about a 5 foot hose. it was around $20 bucks or so. The connectors had different sizes on the ends. I’m going back and get another one so I’ll have two hoses to connect together for more length and the extra connections. I found it where the dist collectors are located. Best I can remember it was in a red box. -- Bruce Free Plans & Calculators https://traditionalwoodworking.org |
#5 posted 01-25-2022 12:33 PM |
Check Amazon I bought an adapter from my kreg jig to a Festool vac. Someone printed it w a 3d printer -- Petey |
#6 posted 01-25-2022 12:45 PM |
Another option is Rockler’s Dust Right system. It has flexible fittings. That’s what I use to contact my Ridgid vac to various sanders. -- Joe | Spartanburg, SC |
#7 posted 01-25-2022 08:46 PM |
Thanks everyone. I really liked the 3D printer idea, however I don’t know anyone. I went to my local Woodsmith store and asked. The sales staff sent me to Lowes where I purchased a flexible drain and trap connector 1 1/2” to 2”. It worked perfectly. So I kind of macgyvered it. |
#8 posted 01-25-2022 09:20 PM |
Ric Yes those rubber plumbing adapters. I have done that myself. -- Petey |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6713 |
8187 |
34183 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5577 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9901 |
