Forum topic by r33tc0w | posted 01-22-2022 05:53 AM | 514 views | 0 times favorited | 7 replies | ![]() |
Recently purchased 3 AMT wood threading dyes (without the taps) and am curious how to go about sourcing the matching taps/making some to match… Any ideas? -- Matthew 13:53-58 |
7 replies so far
#1 posted 01-22-2022 01:13 PM |
I swear by my Beall wood threader and may be a tad above a lot of peoples paygrade… however, if all else fails, you may find this link of some help to match whatever dyes you have… Sorry to sound condescending, but a picture of what you have might have made life easier for those trying to make yours easier… I just hate seeing threads with ”0” replies. -- If your first cut is too short... Take the second cut from the longer end... LBD |
#2 posted 01-22-2022 07:07 PM |
Honestly I don’t have them in hand yet but here’s a couple shots from the auction: -- Matthew 13:53-58 |
#3 posted 01-22-2022 09:26 PM |
As I mentioned, if all else fails the Beall site can give you an indication of what you could be up for using an educated guess. If you are interested in multiple sized threads, I found that the Beall set was cheaper than the same “individual set” of your pictured threaders (new)... though you will need a trimmer/router… but the results are much better… I’ve used both. -- If your first cut is too short... Take the second cut from the longer end... LBD |
#4 posted 01-23-2022 10:44 PM |
I have a set of these I got some years ago. (Woodcraft or Highland Hardware) The same company made both regular and blind taps. -- Barry, in Maryland |
#5 posted 01-26-2022 01:40 AM |
Is 6tpi pretty standard? -- Matthew 13:53-58 |
#6 posted 01-26-2022 06:17 AM |
They’re all 6TPI except for…. so the answer is a probably NOT. -- If your first cut is too short... Take the second cut from the longer end... LBD |
#7 posted 01-26-2022 02:48 PM |
I believe the larger threads 1 1/4” and 1 1/2” are 4. However, I believe the tpi per diameter thread are standard across brands. -- If your first cut is too short... Take the second cut from the longer end... LBD |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6713 |
8187 |
34183 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5577 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9901 |
