Forum topic by kfpsteve | posted 01-19-2022 03:45 PM | 819 views | 0 times favorited | 17 replies | ![]() |
Topic tags/keywords: vega duplicator vega 36 candle holders Hey gang, New to lumberjocks. Newer to turning. Bought a Vega 36 – definitely could use some guidance and have a number of questions. Should I ask away or reach out to someone specifically? Any references, suggestions, input would be greatly appreciated. Steve |
17 replies so far
#1 posted 01-19-2022 05:20 PM |
Do you have questions about the Vega 36, stand height, tools accessories, set-up, turning tools and or? Ask away. |
#2 posted 01-20-2022 01:03 AM |
Ask away. I have a Vega 36” duplicator for quite a number of years so I know a little about them. I haven’t used it ‘A Lot’ but then again when I do it’s the right tool for the job. Started out on a Delta 12” and then with new mounts it’s currently on a Jet 16” (just fyi for anyone considering one of these. |
#3 posted 01-20-2022 01:56 AM |
If we are referring to the Vega duplicator, I have one as well. I started this thread a while back about it: Vega Pro Lathe Duplicator parts and info Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#4 posted 01-20-2022 03:41 PM |
Wow – thanks. First off, I should have used the search function Brad. Sorry for the duplication. No pun intended. Some background (in no particular order – my ADHD struggles with this stuff)..... I have 3 ceramic candle holders – PM 3520C – duplicator mounted on the back of the lathe, with the carbide cutter pointing down. Practicing with ash – chips, dust everywhere. Have to figure out better dust collection. Lots of dust in the bicycle chain. Best way to clean it out? Just getting started….. Thanks in advance. |
#5 posted 01-21-2022 02:10 AM |
When making plastic patterns, I like to lay blue painters’ tape over the whole piece of lexan and cut it with a scroll saw with a fine blade (supposedly there are lexan only blades, but I don’t have them). Once cut, I use a 1” strip sander to clean up and fine tune wherever I can and use some small files in areas too small for the sander. |
#6 posted 01-21-2022 03:32 PM |
Thanks hcbph_1. Will try the painter’s tape and change to 1/8” thick acrylic, cutting at a lower speed with a “plastic” blade. Air chuck – why didn’t I think of that? Makes total sense. Am also going to try a bike chain lubricant / cleaner – that attracts less dust going forward supposedly. Per a YouTube video from Langer Craftworks using a Vega, he duplicated rolling pins at 2800 rpm. In my case, it created a lot of very fine dust. From an experienced friend, he recommended trying at a much slower speed (like 800) and working up from there. Any recommendations for ash or cherry? I have a similar dust hood – will position it much closer to the piece going forward. Have you had any issues with movement of the duplicator bed? Plan to add a washer and lock washer to each bolt. How do you use the locking screw? It does not seem to lock the cutter in place…. does it just reduce the movement of the cutter? (May have to take some photos). What would you use to hold the candle holders on the lathe? Considering one of these: https://www.woodcraft.com/products/woodriver-multi-tooth-drive-center-1-diameter-2-mt Any and all input is greatly appreciated! |
#7 posted 01-22-2022 02:36 AM |
Choosing live and drive centers has a lot to with $ and how much turning you will be doing. I realy like the versatility of this live center. The length is great for bowls and the cones are handy with hollow forms etc. No teeth needed on live centers. This one has a cup around the point to limit depth and splitting. Savannah Heavy Duty Dual Bearing Live Center For Woodworking Lathes and Large or Small Wood Turning Projects. Ultra Smooth Live Center Performance with Minimal Play for MT2 Lathes https://www.amazon.com/dp/B07LHKSSHN/ref=cm_sw_r_cp_api_glt_i_21XMZ0MGD9N7WG7AY39D A cheaper one that will work well I have many drive centers of different shapes and sizes, and up using all of them depending on the project. For the dia of your pieces a 1” 4 spur or one like you linked will work. Penn State tools has many of these types of items at value prices and good enough quality – it doesnt require top $ stuff. Duplicators remove wood by scraping, which will leave some tear out etc, especially carbide. HSS tool bits might leave a bit better finish as they are sharper at 1st. Take shallow cuts to limit wood damage, very shallow as you approach size. If I were doing this job, I would mark or “story board” the pieces, and use bowl gouges for heavy cuts and spindle gouges for lighter cuts to rough out the shape – the will cut faster and cleaner than scraping. Then use the duplicator scraper to finish the last 1/8-1/4” depth of cut. I would then use a negative rake scraper to clean up the surfaces, then sand. The nrs acts a bit like a smoothing plane, leaving a surface only needing finer sanding. Good luck! |
#8 posted 01-23-2022 02:55 AM |
Steve OSU55 |
#9 posted 01-23-2022 02:54 PM |
For drive centers you want a spring loaded center pin, as Mike shows in the vid. I prefer the 4 prong to the 2 prong he likes. 4 blades hold more torque and more area going x grain. I have all the centers he shows plus more. I use steb centers on smaller work and they are less likely to split the piece but dont hold as much torque. For your size work a 1 inch 4 prong will work. I also have this Nova Jumbo drive center I use for starting large bowl blanks and large dia spindle work, 2” dia. It threads on the spindle https://www.teknatool.com/products/lathe-accessories/nova-jumbo-drive-center-sku-9087/ From what I could tell it looks like the vega dupl may use a diamond shaped cupped carbide cutter, but still cutting 90 deg to the grain which is still a scraping cut, or can the cutter be rotated for more of a shear cut? |
#10 posted 01-23-2022 10:10 PM |
OSU55 |
#11 posted 01-23-2022 10:25 PM |
I have both the carbide along with the steel cutters for mine. I like to sharpen the steel one with a good Arkansas stone and keep it for the final cuts as IMO it does better than any carbide can in that situation. Can you post a picture of the steel cutter? I got my duplicator as part of a purchase of a used Jet lathe. I’m pretty sure it has the diamond-v carbide cutter on it as well as the slender turning accessory, but would like to confirm either way. Thanks, -- Brad in FL - In Dog I trust... everything else is questionable |
#12 posted 01-24-2022 01:05 AM |
I have both the carbide along with the steel cutters for mine. I like to sharpen the steel one with a good Arkansas stone and keep it for the final cuts as IMO it does better than any carbide can in that situation. I can get a picture of it but it will probably be a few days before I can dig it out. Paul |
#13 posted 01-24-2022 05:10 PM |
I took some pictures of my Vega Duplicator today, more than just the 1. I made a storage case for it with wheels on it so I can store it vertically, there’s storage areas on both sides of the front for storage. The lid folds up on the top when using the duplicator otherwise it’s fully enclosed. It’s heavy but worth it to protect the unit and parts. |
#14 posted 01-24-2022 05:38 PM |
Thanks for the pictures! I guess I do have the carbide cutter on mine: I also like your storage solution. I just keep mine on the shelf under the lathe, which sometimes gets in the way, and winds up getting covered in wood chips ;( Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#15 posted 01-25-2022 01:28 AM |
Thanks, the storage box works well for me. There are wheels on the right side so it can be easily moved around. |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2077 |
Finishing
6714 |
8188 |
34190 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9903 |
