Forum topic by BlueRidgeDog | posted 01-18-2022 02:52 PM | 487 views | 0 times favorited | 10 replies | ![]() |
I have an assortment of Porter Cable routers. I use them a great deal. I no longer have a plunge base (they break when dropped on concrete from bench level….so I observe). I think I might get one of the new compact routers with a plunge base. Most of my routing is furniture making related, so lighter cuts, more finesse needed than power. What do you recommend? Perhaps I should just buy a new base for my current PC router? Way back in the day, it was PC and Makita, but tools have changed and I have not kept up. I know the stuff I buy now is not as good as what it was. Some are just “zombie” brands that have no connection to the original. I was looking at the Dewalt compact router, you can get a dust port for it, has a nice fence and seems robust. It only takes 1/4” bits, so there is that (all my PC routers can take either 1/4 or 1/2 and I generally buy 1/2…but can buy bits for what I need if 1/4 is the new format). The motor is used in many small CNC systems, so I suspect it is good (soft start etc). |
