Forum topic by skess | posted 01-18-2022 10:53 AM | 393 views | 0 times favorited | 11 replies | ![]() |
Topic tags/keywords: tool Hi, So my questions are - How do you tell if the arbor bearings are in need of changing? Or, should I just change them out because of their age (60 years old). Thanks, |
11 replies so far
#1 posted 01-18-2022 12:08 PM |
If you don’t know how old or what condition the ones in there now are in, replace them. It’s easy to do and cheap insurance against future damage. And it’s easiest to replace them all at the same time while you have things apart. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#2 posted 01-18-2022 07:19 PM |
When I purchased a used Unisaw I changed both plus the belts(3), if you are going through the trouble of doing the motor, I would to the arbor. You can probably do that yourself, I did. The unisaw did not require them to be pressed on, the motor did. For the motor, I took it apart and took it to a local motor shop it was $70 vs $200 for a motor rebuild. -- Rich LI, Life is short, buy more tools ! |
#3 posted 01-18-2022 08:04 PM |
Thanks for the replies guys. |
#4 posted 01-19-2022 12:38 AM |
Getting these bearings onto the arbor is proving difficult. I wish I had access to an arbor press. But, I don’t. |
#5 posted 01-19-2022 02:00 AM |
Shouldn’t need much more than an appropriate sized pipe and a wooden mallet or similar. I hate doing the freeze/heat thing as it causes condensation which can cause problems. Funny side note: I was looking at the parts diagram for that saw over at the ereplacementparts site, and noticed that they have the bearings for it listed at $49.89!! Not sure what you get for that much green, but the picture shows a pretty generic no-name 6203-2RS bearing. Last time I bought 6203’s, they were around $3 a piece for some quality Nachi bearings. Buyer beware! Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#6 posted 01-19-2022 02:05 AM |
I’ve used this shop made unit for pressing on dozens of bearings on motors and arbors. I make up hardwood blocks to the sizes I need for pressing on the inner or outer races as req’d. |
#7 posted 01-19-2022 02:18 AM |
Hey Brad, |
#8 posted 01-19-2022 02:20 AM |
I like that Mike – pretty flexible. |
#9 posted 01-19-2022 02:44 AM |
The bearings for this guy are 88503’s. They are similar to 6203’s except they have extended inner races. LOL – 88503’s were $8 a piece last time I ordered some from Accurate Bearing ;) I’m just amazed at how much these guys can get for off the shelf stuff just because an OEM name is stamped on the box. $50 for $8 bearings is just one example. If you look at the parts available for that saw over at the ereplacement site, you find dozens of examples of standard hardware store items (nuts, bolts, washers, etc…) being sold as if they were made of gold. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#10 posted 01-19-2022 02:48 AM |
Brad, |
#11 posted 01-19-2022 03:57 AM |
I took a look at that site. After I saw the $3 washer and the $4 hex nut, I had had enough. |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6713 |
8187 |
34183 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5577 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9901 |
