Forum topic by ScG420 | posted 01-18-2022 10:11 AM | 1574 views | 0 times favorited | 35 replies | ![]() |
Topic tags/keywords: sander I was wonderinhg what you all thought about this. I would like to have a disc sander that’s at least 9 inches but they’re all just ridiculously expensive. looked into making my own but cant find a good deal on a motor. It wouldn’t save me much $. I noticed wen makes a handheld drywall sander that has a 9 inch disc i think and it’s variable speed (around 1700 – 3400 rpm I believe). Would this work if it was somehow mounted to a bench top? Oh by the way it’s around $65 which is so much more agreeable than $200 |
35 replies so far
#1 posted 01-18-2022 10:33 AM |
I’m sure you could rig something up. My only concern would be the torque of the motor being designed for joint compound. It may take some hunting but the old shopsmiths or even the knock offs can be found cheap on classified ads. I have personally paid 125 for a grey one and 300 for 2 greens. Missed more that one opportunity on them under 150 as well. I love them for dedicated tools. They have an incredible variable speed power plant and make some of the best drill presses money can buy. They also are killer disc sanders. The one I use for disc sanding also has a bandsaw set up on it. I have cut the tubes down on that one making it a shortie which is a great mod to safe a little space if you don’t intended on issuing it as a lathe anymore. -- Master fabricator, novice woodworker. https://www.etsy.com/shop/JFabrication |
#2 posted 01-18-2022 01:10 PM |
Couldn’t agree more on the choice for a Shopsmith. They offer various disc options, too. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#3 posted 01-18-2022 01:30 PM |
Sears used to sell a sanding disk that fit on the table saw arbor. It was just a steel plate with a 5/8” hole drilled in it. I don’t know why you couldn’t make one to fit your needs. It wouldn’t be variable speed, but then that’s never been an issue for me. |
#4 posted 01-18-2022 03:19 PM |
https://www.woodcraft.com/products/woodriver-10-table-saw-sanding-disc-mounting-plate Also, do you have a lathe? There is a project around that shows a table mounted on the ways and a disc in the motor. |
#5 posted 01-18-2022 04:54 PM |
There was a table saw sanding disc on Amazon for $ 38. Made by CMT if I remember correctly. |
#6 posted 01-19-2022 11:33 AM |
Thank you guys for all the help. for now I found the cmt disk for the table saw and some adhesive backed disks and it only set me back about $40. It should be sufficient for my needs |
#7 posted 01-19-2022 02:34 PM |
Hope it works for you. |
#8 posted 01-22-2022 02:01 PM |
I have read a number of articles that recommend against ”tablesaw discs”... suggest you do some due diligence before your $40 purchase turns into a few hundred $’s dead TS. Just passing on rumours I’ve heard/read. I apologise for being a stick in the mud… nevertheless Welcome to LJ. The fact that you’ve already realised you need a large disc sander should ring bells that you are entering a not too cheap hobby/venture. +1 for brtech’s lathe challenge. -- If your first cut is too short... Take the second cut from the longer end... LBD |
#9 posted 01-22-2022 03:21 PM |
What are the rumors? |
#10 posted 01-22-2022 03:26 PM |
Look for a belt sanding disc from Craftsman.. craigslist, marketplace.. |
#11 posted 01-22-2022 04:25 PM |
It has to do with the motor on Craftsman saws not being enclosed and sealed. Even without a sanding disk mine would suck itself full of dust and debris from time to time. I would have to take the ends off and clean it out. Just the nature of the beast. I lived with it for 20 plus years. My son has the saw now, same original motor and still running strong. |
#12 posted 01-22-2022 04:40 PM |
I tried using a table saw sanding disc once upon a time, it did not work out, as table saws have way too high rpms and the disc burned everything that touched it. -- Bondo Gaposis |
#13 posted 01-22-2022 09:14 PM |
Sorry ibewjon, but I stopped taking records of my reading sources many years ago. For some stupid reason, I seldom see a manufacturer say “Buy our tablesaw discs as they will bugger up your saw.” I tried them years ago, didn’t work too well for me or any serious woodie I’ve discussed it with… just spreading bullshit so that others may think twice. -- If your first cut is too short... Take the second cut from the longer end... LBD |
#14 posted 01-22-2022 09:40 PM |
I have a 12” disc from Shopsmith that fits a 1/2” motor shaft. I have it setup with a table for sanding. I’ve been using it for over 20 years. The motor I put on it was only 1/3 HP. The disc slows down if too much force is used against the sanding surface. A 12” disc requires at least 2 HP to work the best and 1725RPM is maximum. Look around for a Shopsmith sanding disc on Ebay or Craigs list. |
#15 posted 01-24-2022 03:05 PM |
I have seen many instances on YouTube where people have made disc sanders from drills. I don’t know about a 9” sander though. That might be too much torque for a regular hand drill. I’ve contemplated buying the cheapest belt driven drill press in Harbor Freight and just taking the motor from that and throwing the rest out. -- Tony, SW Chicago Suburbs |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2077 |
Finishing
6714 |
8188 |
34190 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9903 |
