Forum topic by Thomas C. | posted 01-17-2022 04:05 AM | 1301 views | 0 times favorited | 47 replies | ![]() |
Topic tags/keywords: bench design moravian nicholson roubo scandinavian holtzapffel schwarz anarchist sellers siemsen I’m new to hand tool work and recently moved to a home with a smaller shop in it – 16’x10’. So now I’m fighting which bench design do I think I’ll want and after reading and reviewing countless articles, blogs, and videos I’ve realized many people don’t say why they chose one form over another. My big projects will be jewelry boxes, picture frames, coasters/cutting boards, maybe some ring boxes. I think I’ll like the Nicholson / Moravian designs and maybe add a moxon vise for detailed work. Out of curiosity though what made you choose your design? |
47 replies so far
#1 posted 01-17-2022 04:37 AM |
For the projects you mentioned, you can get by with a 2’×4’ work bench. I don’t do a lot of traditional hand tool work. My main work bench is 4’×4’ with three cabinet vises. Which doubles as a extension table to the table saw. I like the extra room on the 4’×4’ work bench to stretch out the work pieces. Or spread out pieces for multiple projects. I currently have three different small projects, spread out on this work bench. You may need to consider the space needed for the bar clamps, while doing glue-ups for the cutting boards. My assembly and glue-up bench is 2’x8’. The bench I use for staining and finishing is 3’x5’. A small HomeRight Spray Shelter sits nicely on it, when I use the shelter. Both these two benches are in a different room than my main workshop. |
#2 posted 01-17-2022 04:49 AM |
I have a first generation Lie Neilson bench top. I made a beefier base then they offered. -- Aj |
#3 posted 01-17-2022 09:58 AM |
I have made for myself a (solid wood) Paul Sellers workbench: - It is not difficult to make; I have also used it to make a Moravian workbench (https://eclecticmechanicals.files.wordpress.com/2018/08/themoravianworkbenchbywillmyers.pdf )for the son because: some reflection about mass: About height: there is a study which shows that the height which minimise pain in various parts of the body (back, neck, shoulder, elbow, wrist, ...) is about 15 cm below elbow height (with your shoes on). For me it correspond to Paul Sellers recommendation. My only regret: having procrastinated too long. -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn (and that is nice) |
#4 posted 01-17-2022 11:01 AM |
Sylvain pretty much hit it on the head. I have a roubo, solid hard wood, amazing bench etc. you can see it in my projects. However, I didn’t start with this bench. I started with the Paul sellers bench and used it for many years. And I think you should start there. It’s not insane expensive to make and you will learn what you need/don’t need, want/don’t want and what works for you. The height of my last bench sucked. I have some lower back issues so I need a bench that’s a little higher. I didn’t know that until I worked on my Paul sellers bench. Vises, what do I wish I had that I didn’t already have…incorporate those in the final shot. You find you hate hand tool work, change the design all together. Loads of questions there’s no way you have the answers to right now. Paul sellers workbench is a serious perfect starter bench. Moravian might work too for you just think it through. Just my .02. -- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools |
#5 posted 01-17-2022 11:43 AM |
I am a Moravian bench fan here. Built it out of mostly Southern Yellow Pine with some red oak for the small side stretchers. White Oak for the leg vise and maple screw from lake Erie tool works. I also bought the wagon vise form Will Myers and highly recommend it. I like that I can break it down by myself if I ever need to move it. It is very stable and solid for hand tool work. I ended up making it just shy of my table saw height (SawStop jobsite) to double as outfeed table and not obstruct table saw work. It feels like a good height to me. I have the exact same size shop as you and often need to slide it a bit to make the most of my small space. Any bigger or heavier and it would be a problem. It was my first big non-plywood project and was a really fun build. Tip, get 2×10 or 2×12 to make the laminated top by ripping out the center portion of each. You are never going to get all the boards dead even in the to so don’t stress over it. Get a good edge on a hand plane and go at it to flatten it. I also had the “I need a bench to build a bench” issue so I made the top first and placed if on saw horses to work off of. Good luck and have fun. |
#6 posted 01-17-2022 11:54 AM |
In the early 90’s I purchased a video on “Make a Dovetail Drawer” by Frank Klausz. It was the first time I ever saw a Scandinavian cabinetmakers bench, and I knew eventually I would make my own. That didn’t happen until nearly 25 years later. After using the bench for 6 years, I’ll give you my thoughts. Overall, I am very happy with the size and utility of the bench. The tail vise has become a little loose, mainly b/c I believe the build rails have shrunk a bit. Easy fix, just not enough of an issue to bother with it. Had to do over, I would bite the bullet and go with the quick release hardware. Shoulder vise. This is the one aspect of the bench I’m a little hesitant to recommend, only b/c it does take up some room, and for some people, the vise jutting out might be an issue. Again, had to do over, I would use a twin screw or a built in Moxon. The Scand bench has served me well for both hand and power too work. -- Everything is a prototype thats why its one of a kind!! |
#7 posted 01-17-2022 01:46 PM |
I simply looked at what I do and what I wanted to do. Then I decided how I wanted the bench to hold the wood. For me that was end vice with dog holes for planing the face of the board. -- Jeff Horton * Kudzu Craft skin boats* www.kudzucraft.com |
#8 posted 01-17-2022 02:09 PM |
I also had the “I need a bench to build a bench” issue so I made the top first and placed if on saw horses to work off of. Good luck and have fun. I used a workmate to make my first workbench-top, then pinched it on the workmate to make the other components. It is a good recommendation to start with the bench-top. Trestles without using a workbench to start: -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn (and that is nice) |
#9 posted 01-17-2022 02:18 PM |
I decided on a Roubo, after many years working on a flimsy bench that would walk across the shop when hand planing. I wanted a beefy and stable bench. I don’t regret my decision. I was a little bit apprehensive about the wagon vise instead of an end vise. That turned out well also, I don’t miss the end vise. -- Bondo Gaposis |
#10 posted 01-17-2022 02:42 PM |
My bench isn’t a traditional bench. I did a lot of research and came up with a mish-mash of requirements that I wanted in my bench. - As inexpensive as possible After 7 or 8 years, I’m still very happy with it and have no desire to build a new one. It’s sturdy as hell The end vice is pretty much unused nowadays, due to shop overcrowding. In fact, I’m most frustrated by my lack of space to use the bench in all the ways that I had envisioned using it. -- Tony, SW Chicago Suburbs |
#11 posted 01-17-2022 02:58 PM |
I am in almost done building my adaptation of Chris Schwartz’s Anarchist Workbench which is his adaptation of a Roubo. I went back and forth between it and the Moravian design but ultimately settled on the Anarchist approach because of the Hovarter quick release vise hardware that I chose. I didn’t think that it would work well with the Moravian design. BTW, If you go to Chris Schwartz’s web page for the Anarchist Workbench, he offers his ebook “The Anarchist Workbench” for free. In it he reviews most of the common workbench designs which might help you make up your mind. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#12 posted 01-17-2022 03:09 PM |
Bench? My “bench” is my saw top. Flat, stable, solid as a rock. -- The hump with the stump and the pump! |
#13 posted 01-17-2022 03:20 PM |
Lots of good stuff here, makes me want to go out to the shop and start customizing my bench. Right now I am using the stretchers as my clamp rack. |
#14 posted 01-17-2022 04:07 PM |
First, You will probably build more than one workbench in your lifetime, for various reasons, moving being among them. -- Barry, in Maryland |
#15 posted 01-17-2022 05:22 PM |
Good recommendation here. I overanalyzed the same thing for a couple of years and eventually went with Richard Maguire’s english joiner bench. This was before Schwarz finished the Anarchist bench book. chris Schwarz has made several of every bench imaginable, even ones you’ve never heard of. So he has taken the good arts of each style and combined them into one. Kind of doing all the work for you. |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2077 |
Finishing
6714 |
8188 |
34190 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9903 |
