Forum topic by xeddog | posted 01-16-2022 08:49 PM | 738 views | 0 times favorited | 9 replies | ![]() |
My DIL gave me 5 boards to make into cutie boards for her (I volunteered), but this one cedar board is outside of my comfort zone. It is twisted quite a bit, and if there is a direction to warp, this board seems to have found them and maybe a couple of new ones. The biggest issue though, is twist. The first picture shows the general shape and condition of the board, including the decayed hole which I plan to fill with a colored epoxy. The second shows some of the twist. The board has a weight on the far narrow end which only has about 5-6” on the table, and the gap on the right front is about 3/16” or so. I could flatten it the same way I did the other 4 boards flat using my drum sander, shims, and a lot of time, but I am thinking that this board would them only be about 1/2” thick at the most when done. The only other thing I can think of that might work is Steaming. Could a board like this be steamed, and then supported/weighted appropriately to make the “bend” more permanent? Thanks. Wayne |
9 replies so far
#1 posted 01-17-2022 01:36 AM |
It doesn’t look like a very good cutting board. -- Aj |
#2 posted 01-17-2022 03:45 AM |
Is a “cutie” board a cutting board? If so, hard pass. I wouldn’t mess with those. If “cutie” is some other new etsy fad that doesn’t involve food or needing to do anything more than just sit there then go for it. I don’t thing steaming is going to allow it to be moved back and stay significantly flatter, just plane it down to where it needs to be and hope it’s thick enough. -- “I never in my life thought I would have to say this, but the proper role of government is not to fund the distribution of crack pipes,” Lauren Boebert |
#3 posted 01-17-2022 05:50 AM |
I suspect you are talking about a charcuterie board, which is the current “in” name for a cutting board. Youre thinking of spending $100 and 50 hours on a $10 board? Either cut it into strips and glue the good bits back together, or toss it on the bonfire. -- my projects can be seen at www.pbase.com/sunnybob |
#4 posted 01-17-2022 03:29 PM |
Firewood in my opinion, life is too short. -- Bondo Gaposis |
#5 posted 01-17-2022 04:49 PM |
Just a couple of things. Yes, they are charcuterie boards but I just hate that name, and I thought they were more a serving tray rather than a cutting board. Second, it’s not my money and she has already bought the epoxy. Lastly, I have plenty of time on my hands lately so I’m not going to be losing anything. So I guess I will plod ahead knowing that I most likely won’t get the desired result. |
#6 posted 01-17-2022 04:56 PM |
If used as a charcuterie board only the bottom needs to be flat, and even at that just enough that it’s stable. Cheese and cured meats don’t care if they’re plumb and square. Take off just enough from the bottom so the board doesn’t rock in any direction, and just smooth the top. |
#7 posted 01-17-2022 04:58 PM |
You might not like the word, but if you insist on making up one you like, expect constant confusion and questions. Just for reference, the origin of the name has almost nothing to do with boards or trays Charcuterie (shar-KOO-ta-REE) is a specific term with origins reaching as far back as 15th century France; literally translated, it means the products of a fancy pork butcher. Modern charcuterie does often include pork, but the definition has widened to reflect a dish served throughout many cultures. If you are going to go ahead, treat it as a steep learning curve, with low expectations.
You also need to start watching -- my projects can be seen at www.pbase.com/sunnybob |
#8 posted 01-17-2022 05:15 PM |
I think you can make her happy just doing what you indicated but the best way to “flatten” the boards might be with a router planer set up. There are lots of videos on the internet on how to do that so I won’t belabor the idea here. Another way is to get the top flat and then add some sort of leveling supports to the bottom like blocks of rubber or wood cut to the thickness needed. I can’t see where steaming would work here and the wood most like would only revert when it dried out. You didn’t mention a finish. I like to use processed Walnut oil on this type of project (Mahoney’s or Doctor’s) for a more natural finish, but because this wood seems to want to move it might be better to seal them using a salad bowl finish like Behlen’s or Generals. They are a hard top coat finish that can be wiped on. Four or five coats sanded lightly between coats should do it. I use this all the time on salad bowl and it is very durable….and food safe. Good luck -- Les B, Oregon |
#9 posted 01-19-2022 01:57 PM |
As much as I hate to say this, glue some contrasting feet on it. Don’t just glue blocks of wood on but make them interesting. Make them different heights so that the top sits flat. You could even make a “carriage” that it sits in so that it sits flat. I wouldn’t try to steam it or try to plane it flat. Work with what you got. -- NorthWoodsMan |
Forum | Topics |
Woodworking Skill Share
13543 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6712 |
8187 |
34181 |
CNC Woodworking
384 |
Hand Tools
6769 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5577 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9900 |
