Jet belt sander new belt runs to right.
Forum topic by stripit posted 01-14-2022 01:33 AM 232 views 0 times favorited 9 replies Add to Favorites Watch
View stripit's profile
stripit
160 posts in 3374 days
01-14-2022 01:33 AM
Topic tags/keywords: sander question sanding
I have Jet JSG- 96 belt sander, and the new belt will not track, it goes to the right. I have turned the adjusting knob both ways but it still goes right. I unlock it before adjusting, I loosen the tension and center the belt then tighten it.
It still goes to the right. What am I missing.
Any suggestions. Thanks.
-- Joel, People ask what I make. I tell them I make sawdust, and now and then a nice box or frame,or clock, or lamp pops out.
9 replies so far
View JackDuren's profile
JackDuren
1772 posts in 2290 days
#1 posted 01-14-2022 01:44 AM
New machine or just a new belt? Brand belt.
stripit
#2 posted 01-14-2022 01:56 AM
New belt, machine is 10 years +.
View JCamp's profile
JCamp
1528 posts in 1881 days
#3 posted 01-14-2022 02:58 AM
Never messed with one but my guess is the belt is off. One sure what to find out is get another and try it. It it works then the first belt is messed up. If not possibly the machine. No clue how much them belts cost but maybe try another brand. Also you could run a string around each edge of the belt and see if one side is bigger than the other which would throw off tracking
-- Whatsoever thy hand findeth to do, do it with all thy might
View waho6o9's profile
waho6o9
9130 posts in 3907 days
#4 posted 01-14-2022 03:24 AM
Reverse the belt?
View KelleyCrafts's profile
KelleyCrafts
4774 posts in 2070 days
#5 posted 01-14-2022 03:29 AM
Wahoo has the only potential fix otherwise I bet the belt was cut/stitched wrong.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
View splintergroup's profile
splintergroup
6319 posts in 2553 days
#6 posted 01-14-2022 07:29 PM
I agree with Wahoo, reverse the belt and see if it goes to the left. Most likely a slip up when they spliced the belt.
View Lazyman's profile
Lazyman
8755 posts in 2718 days
#7 posted 01-14-2022 08:23 PM
Yup, reverse it and if it goes the other way return the belt as defective.
stripit
#8 posted 01-14-2022 09:38 PM
Hi. I just trried turning the belt around, same result, I tried a defferent belt, no change.
if The wheel dose the adjustment, what is the bolt for???
splintergroup
#9 posted 01-14-2022 11:44 PM
The tension and cant adjustments should operate independently. Install the belt, tension, then adjust the cant.
Sorry for saying anything obvious, but one just never knows how familiar people are with their tools unless they have stated so. 8^)
