Forum topic by tcaz | posted 01-13-2022 04:52 AM | 1353 views | 0 times favorited | 14 replies | ![]() |
Looking for some ideas on how to construct a ~23-26” diameter drum table base (see photo) for a 48”D top made from 8/4 maple. Was thinking some sort of inner structure with 3/4” ply discs or circles for the shape, then wrapped in a thin substrate with hardwood veneer over it. Or kerf cut ply to wrap the drum? How would one go about it with all hardwood? This is a first for me so any and all insight and wisdom are appreciated. Thanks! |
14 replies so far
#1 posted 01-13-2022 11:57 AM |
spend some time checking these blogs out, they may be of assistance https://www.lumberjocks.com/robscastle/blog/37247 -- Regards Rob |
#2 posted 01-13-2022 12:11 PM |
A veneer wrapped sono tube would work. Reinforce with 1X2s on the inside. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#3 posted 01-13-2022 01:37 PM |
you can actually buy flexible plywood, that is made specifically for this purpose. There are many websites and if I recall correctly, they post minimum bend radius. |
#4 posted 01-13-2022 02:10 PM |
do it the way one would do a bucket. one project from Mafe: -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn (and that is nice) |
#5 posted 01-13-2022 02:58 PM |
It could be done like the turning blank of a segmented bowl with long boards with angled edges. -- You know, this site doesn't require woodworking skills, but you should know how to write. |
#6 posted 01-13-2022 03:45 PM |
we used soni tube and wrapped with veneer, with a couple stiff backs inside tube to keep it rigid for weight sorry gene didn’t see your post till after i posted this, simplist way to do imo -- Living the dream |
#7 posted 01-13-2022 03:58 PM |
How did you adhere the veneer to the sonotube? I’m not familiar with them other than a quick google search. Do you have any photos of the project or process by chance? |
#8 posted 01-13-2022 06:34 PM |
Look at using a birds mouth joint that is easily cut on table saw. The sail boat DIY community has really helpful material online. They even show to make tapered conical shapes. Can download the calculators here Another option not mentioned already and used in commercial builds; is covering a curved structure with Bendy ply or flexible plywood; which is smooth flat substrate for thick veneer (usually paper backed). If deep down you wanted some fancy lathe turned column (and have budget for it); there are several folks that offer custom large diameter turning. Look at Blue Ox Mills, Hanson Woodturning, or Osborne Wood Products. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#9 posted 01-13-2022 07:15 PM |
no sorry, pretty sure the boys sprayed a contact cement, rolled the veneer on and put it in a vaccum press. other option use soni tube, and rip pcs to fit around it. have seen that done, -- Living the dream |
#10 posted 01-13-2022 08:48 PM |
Check out Anderson International Trading. They sell paint grade and veneered round table bases in the size you need. The one in the picture looks coopered from solid wood. |
#11 posted 01-14-2022 11:43 AM |
+1 -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn (and that is nice) |
#12 posted 01-17-2022 03:21 PM |
^ This is how you would do it with hardwood. Much like a wooden barrel. Use a tablesaw to cut a slight angle on the long sides of each plank then glue it all together. It will form a faceted circle. Then you plane or sand the corners to make it nice and round.
“Cooper” is an old-timey term for someone that makes barrels using this method. Anyone with the last name “Cooper” probably had an ancestor that made barrels in England before last names became a thing among non-nobles. -- Tony, SW Chicago Suburbs |
#13 posted 01-17-2022 04:11 PM |
Well TIL that SonoTubes are available up to 36” diameter! I’ve used the 12-16” tubes from the box stores before to create simple and lightweight tables and stands for trade show merchandise displays. Contact cement and you can wrap them with almost anything flexible – carpet, Formica, wood veneer. I cut some plywood disks to help them maintain their shape because the took some abuse. I still have a set almost 15 years later. One thing to consider is that the design isn’t that stable with a wide top. I used a foot for my tall displays, and for the short ones, the top was removable and I had a 5/8” dowel sticking up in the base and dropped a pair of 5# dumbbell weights into the base to prevent it from tipping over. -- Glenn, Jersey Shore, NJ |
#14 posted 01-17-2022 05:04 PM |
I’d do it with solid wood too. I recently made a coopered wastebasket with staves and found it surprisingly easy and very fun to make. I cut the staves square on the tablesaw (these were tapered, yours wouldn’t be), marked both ends of each stave with a bevel gauge and used a handplane to get the angle on both sides of each stave. I then had to hollow each stave by hand before glue-up, but you won’t need to do this. You could shape the outside with planes, spokeshaves, scrapers, sanders. The more staves you use the less post-glueup shaping there is to do. -- Jeremy, in the Acadian forests |
Forum | Topics |
Woodworking Skill Share
13543 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6712 |
8187 |
34181 |
CNC Woodworking
384 |
Hand Tools
6769 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5577 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9900 |
