Forum topic by dbw | posted 12-11-2021 06:21 PM | 752 views | 0 times favorited | 24 replies | ![]() |
Topic tags/keywords: wood outdoors spar urethane I got tired of my ashtrays being blown around by the wind so I decided to make wooden “weights” for them. I’m thinking of using 5” X 5” pieces of either 8/4 or 12/4. The question is: what is the best wood for something which will live outdoors 24/7/365? I’ve heard white oak is good for outdoors. Is there a better choice? Will Spar Urethane be acceptable as a finish? FYI I will be epoxying the ashtrays to the bases. -- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy. |
24 replies so far
#1 posted 12-11-2021 08:15 PM |
LOL Good Luck! We get 40-70MPH straight line winds during every monsoon season. Ashtray on 5×5 wood block will sail away even faster than lower profile tray alone. Skip wood and use something really dense. Maybe buy a 1/4 thick 8×8 steel plate and finish with a nice artist grade patina from Sculpt Nouveau products. Cheaper route would be to use concrete or a decorative brick. Being cheap I once used JB Weld slow cure epoxy and bonded couple of cigar ash trays to a 8×8 octagonal patio brick for my patio. They only lift up and fly around back yard when it blows over 80MPH every couple of years. -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#2 posted 12-11-2021 08:28 PM |
Lignum Vitae might work. |
#3 posted 12-11-2021 08:29 PM |
You can use Ipe or black locust. Both are dense and heavy. |
#4 posted 12-11-2021 08:31 PM |
what is Ipe? -- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy. |
#5 posted 12-11-2021 08:47 PM |
You can use Ipe or black locust. Both are dense and heavy. – corelz125https://www.wood-database.com/ipe/ http://www.hobbithouseinc.com/personal/woodpics/ipe.htm -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#6 posted 12-11-2021 09:09 PM |
+1 ipe -- The hump with the stump and the pump! |
#7 posted 12-11-2021 09:25 PM |
Of course there is the problem of the ashtray holding the water, it is a bowl after all 8^) If your table is metal, you can embed some RE magnets to keep them from becoming the property of your neighbors. +1 on the ipe. Lots of other tropical woods that will do well too. |
#8 posted 12-11-2021 09:49 PM |
Quit smoking is best solution -- Aj |
#9 posted 12-11-2021 09:53 PM |
I quit in 1987. I can’t convince my wife to do the same. -- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy. |
#10 posted 12-11-2021 10:05 PM |
Maybe if there aren’t any ash trays…? -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#11 posted 12-11-2021 10:39 PM |
Good luck with this angle!!! -- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy. |
#12 posted 12-12-2021 06:06 AM |
id use ipe for sure.how about putting them a way when not in use ? and yeah get her to quit,or smoking will quit her ! -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#13 posted 12-12-2021 09:33 AM |
Drill into the bottom and pour some lead in the holes, then plug them. |
#14 posted 12-12-2021 11:25 AM |
How about a half sphere ashtray with the flat as bottom? -- If you lose, don't lose the lesson. |
#15 posted 12-12-2021 04:46 PM |
Here is the kind of ashtray I need to weigh down: -- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy. |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2077 |
Finishing
6714 |
8187 |
34189 |
CNC Woodworking
384 |
Hand Tools
6770 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9902 |
