Another 12-inch Disc Sander Question
Forum topic by Sewermann posted 12-09-2021 09:10 AM 346 views 0 times favorited 5 replies Add to Favorites Watch
View Sewermann's profile
Sewermann
11 posts in 573 days
12-09-2021 09:10 AM
Supergrit.com, and others I’m sure, sells a 12” PSA Velcro hook disc for application to your 12” disc sander platen, as well as a variety of Velcro loop-backed sanding discs for attachment. Does anyone here have any experience with such a set-up. Your thoughts please. Thank you.
5 replies so far
View Gene Howe's profile
Gene Howe
12487 posts in 4770 days
#1 posted 12-09-2021 09:41 AM
I find the H&L system lacks the rigidity to do the tasks asked of it.
7363 posts in 3835 days
#2 posted 12-09-2021 11:33 AM
I’m in Gene’s camp, there is some softness in the pad with H&L, and i wouldn’t want that on a disc sander. Another concern (to me) is the heat. In use I seem to always heat the workpiece up on the disc sander (that’s actually really easy to do)...and that’s death to hook pad.
View Knockonit's profile
Knockonit
1073 posts in 1544 days
#3 posted 12-09-2021 12:41 PM
a long session of sanding will heat up the pad and the hook goes south, especially if one does not rotate or move area you are sanding on disc. the psa is the standard as far as i’m concerned,
good luck with selection
rj in az
-- Living the dream
Sewermann
#4 posted 12-10-2021 05:55 AM
I hear you loud and clear. Thanks guys.
View therealSteveN's profile
therealSteveN
9403 posts in 1916 days
#5 posted 12-10-2021 06:14 PM
That sponginess you’ll get will almost negate any “possible” accuracy you will get from PSA. I did this experiment years ago. Ended poorly. I think for the quick change you hope for, then Ducks idea of extra platens will end up being your best end, but as many opined in the initial thread, there is a tight range of effective grits to be used. If you want to stick to a single do trials with 120, 150. I imagine in the end you’ll end up with either 80 or 100, maybe 120?
-- Think safe, be safe
