12-inch Disc Sander Question
Forum topic by Sewermann posted 12-09-2021 08:32 AM 367 views 0 times favorited 6 replies Add to Favorites Watch
View Sewermann's profile
Sewermann
11 posts in 573 days
12-09-2021 08:32 AM
I thoroughly enjoy using my 12” disc sander, and am considering the purchase of a second one so that I can move to a second grit without all the hassle of changing papers. My current disc sander usually has an 80 grit disc on it. So my question is this:. If you had an 80 grit disc on your sander, and bought a second one, what grit disc would you likely keep on the second one? Thanks.
View WhyMe's profile
WhyMe
1429 posts in 2903 days
#1 posted 12-09-2021 01:44 PM
Probably 120.
View Woodchuckswife's profile
Woodchuckswife
154 posts in 2652 days
#2 posted 12-09-2021 01:50 PM
It is one of my most used tools. ,I would say 120
Chuck
View HokieKen's profile (online now)
HokieKen
20734 posts in 2480 days
#3 posted 12-09-2021 07:06 PM
I can’t see much use in going finer than 120. It’ll just clog and burn up in short order. I’d go to 120 as well. 220 maybe if it was a variable speed motor I could slow down.
I don’t know how the disc platen attaches to your machine but would it be possible to buy a second platen and keep a different grade paper on there and just swap the platen out? Might be just as much hassle as swapping paper but thought I’d throw it out there…
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View LittleBlackDuck's profile
LittleBlackDuck
8693 posts in 2163 days
#4 posted 12-10-2021 02:44 AM
Do you have a lathe? You could make as many platens as you like (can afford) and mount whatever grit you want. If you thread the spindle mount rather than chuck, changeout takes seconds with minimal/negligible runout.
While dust collection is another issue, but it wouldn’t be your workhorse.
View LeeRoyMan's profile
LeeRoyMan
2398 posts in 1069 days
#5 posted 12-10-2021 02:54 AM
Have you ever used other grits on your present sander, which do you like besides the 80g?
If you haven’t tried any others, then experiment and use what works best for you.
100g is probably as high as I would go.
Sewermann
#6 posted 12-10-2021 05:51 AM
Thanks for your recommendations, guys. Much appreciated.
Ducky, after nearly 50 years in the shop I have no lathe. No room, unfortunately, but thanks for the suggestion.
LeeRoy, the only other grit used was 100, and I didn’t notice much difference between the two. Have been considering 100 and 150, both in alumina-zirconia. I’ll report back if I have success with that arrangement.
