DW735X & (DW7350) stand owners, check these bolts.
Forum topic by OldBull posted 12-08-2021 07:42 PM 676 views 0 times favorited 7 replies Add to Favorites Watch
View OldBull's profile
OldBull
557 posts in 630 days
12-08-2021 07:42 PM
Good Afternoon,
My DW planer was really struggling lately and I knew it was probably time to reverse blades. Yesterday I found a nut on the floor and did not readily see anything missing on my tablesaw. On the last piece of leopard I was planing the vibration was bad enough to make me feel it in my stomach. Today while changing the blades I saw the loose bolt on the planer stand. All of them were loose. I tighten everything really well and I used all the washers that came with it. Next time your in the shop give these a tighten.
7 replies so far
View GaryCK's profile
GaryCK
143 posts in 1384 days
#1 posted 12-09-2021 02:35 AM
Thanks for the tip. I’ll check mine next time I’m in the shop.
-- Gary, Wisconsin
View Eric's profile
Eric
2843 posts in 1208 days
#2 posted 12-09-2021 03:14 AM
Thanks for the heads up. I just purchased a 735, however I did not get the stand. Plan to build one making it sturdy.
-- Eric, building the dream
View Aj2's profile
Aj2
4224 posts in 3133 days
#3 posted 12-09-2021 05:53 AM
I can see the lace wood being so hard as the blades become it could be it’s rattling your stand to pieces.
When I had a 735 I used it a lot on Exotic woods. Instead of the insert head I bought infinity carbide tipped knives.
I recommend them instead of insert head. The carbide they use is very high quality and fine grained. Easy to resharpen.
Good Luck
-- Aj
View Rich1955's profile
Rich1955
393 posts in 725 days
#4 posted 12-09-2021 01:59 PM
If your having trouble with bolts coming loose from vibration, put a drop of thread locker on each bolt before you tighten it. If you need to remove it at a later date just heat with a heat gun and it will come right off.
-- Rich
OldBull
#5 posted 12-09-2021 03:44 PM
Thanks AJ2 and Rich, AJ I wanted to get the carbide tip but you know how reviews go, it is nice to get first hand info and that makes my decision. Rich I have never had any nuts on anything ever come loose, I often break off bolts when tightening if I am not careful. I am going to try one more time with tightening and then I was going to go with blue.
OldBull
#6 posted 12-09-2021 08:03 PM
I don’t know about the carbide tip blades now, single edge set of three is 250 bucks but last ten times longer, I will have to think about that one.
View Aj2's profile
Aj2
#7 posted 12-09-2021 08:32 PM
I don t know about the carbide tip blades now, single edge set of three is 250 bucks but last ten times longer, I will have to think about that one.
- OldBull
It sure is expensive. Here is another after market blade to consider t1 .https://www.holbren.com/dw-735-t1-planer-knife-set/
They used to offer carbide tipped not sure if they do anymore.
Here’s a pic of a fixture to hone 735 knives when they dull. The angle is 45 and the plastic diamond hinge is a smith.
Good Luck
-- Aj
