Inlay into solid wood table top - is it possible
Forum topic by SteveGerard posted 12-06-2021 11:06 AM 327 views 0 times favorited 2 replies Add to Favorites Watch
View SteveGerard's profile
SteveGerard
2 posts in 46 days
12-06-2021 11:06 AM
Topic tags/keywords: inlay cross grain router marquetry
Hello – I’m new to inlay work and am wondering if it is possible to do inlay into a SOLID 1” thick quarter-sawn white oak table top having a 18 inch diameter. I will use the router method for removing wood, then chisels to creep up to the marked line. I’m thinking of using thin lumber for the inlay – like 1/8” thick or maybe 3/16” thick. Attached is a drawing of my proposed design. I’m concerned with wood movement and the inlay could crack or pop out?? The blue lines show the table top is built/glued up from 4 separate boards, each board 4-3/4” wide.
2 replies so far
View Robert's profile
Robert
4835 posts in 2816 days
#1 posted 12-06-2021 11:51 AM
No problems with that dimension — as long as wood is dry enough.
View Gene Howe's profile
Gene Howe
12474 posts in 4763 days
#2 posted 12-06-2021 11:51 AM
Easily done. Make a negative template from 1/8” masonite hardboard and use a flush trim bit like the Amana Tool – 45475-S Carbide Tipped Flush Trim Plunge Template 3/8 Dia x 1/4 shank.
