How to plane narrow strips upright?
Forum topic by noone posted 12-04-2021 01:50 PM 444 views 0 times favorited 12 replies Add to Favorites Watch
View noone's profile
noone
590 posts in 3603 days
12-04-2021 01:50 PM
I’ve got a 3/8” thick piece of UHMW that I bought to use as runners for a crosscut sled. My plan was to cut them 1/16” wider than the table saw miter slots then sneak up on a perfect fit in the planer with the strips upright. The problem is I can’t figure out how to do this. Is the only way to accomplish this is by hot gluing it to a wider board the same thickness and then run it through?
12 replies so far
View drsurfrat's profile (online now)
drsurfrat
1214 posts in 517 days
#1 posted 12-04-2021 02:01 PM
That sounds like it will work. You might try a longer hand plane as an alternative. UHMW plastics hand plane very nicely.
That is a plastic that is very oily, make sure that the glue sticks so that you done’ have a spear-like projectile
-- Mike (near Boston) ... Laziness is the mother of invention, necessity is the mother of exhaustion - me
noone
#2 posted 12-04-2021 02:21 PM
Or maybe I should just sneak up on the width of the cut on the tablesaw! Duh!
View Kudzupatch's profile
Kudzupatch
356 posts in 2539 days
#3 posted 12-04-2021 02:25 PM
Screw it to a solid piece of wood of the same thickness. Then plane both.
I don’t think you will never glue it to anything and if you try you are taking a BIG risk.
-- Jeff Horton * Kudzu Craft skin boats* www.kudzucraft.com
View Lazyman's profile
Lazyman
8755 posts in 2718 days
#4 posted 12-04-2021 02:45 PM
Don’t complicate things. I would just use the table saw. Start 1/32 over and nudge the fence until they fit.
View jonah's profile
jonah
2273 posts in 4629 days
#5 posted 12-04-2021 03:41 PM
I’m not even sure hot glue would stick to UHMW.
View SMP's profile
SMP
5049 posts in 1236 days
#6 posted 12-04-2021 04:32 PM
Just clamp it in a vise and sneak up on it with a hand plane
View controlfreak's profile
controlfreak
3192 posts in 932 days
#7 posted 12-04-2021 04:51 PM
Clamp a supporting piece and UHMW in a vise and plane it.
View BurlyBob's profile
BurlyBob
9508 posts in 3596 days
#8 posted 12-04-2021 05:21 PM
I agree with SMP.
View corelz125's profile
corelz125
4054 posts in 2307 days
#9 posted 12-04-2021 05:23 PM
If you have a shoulder or rabbet plane you can plane it down after you attach it to the base.
noone
#10 posted 12-04-2021 05:40 PM
I don’t have a hand plane. I do have a card scraper I bought and have never used. Wonder if that will work. I guess I can try it.
View Andre's profile (online now)
Andre
4993 posts in 3136 days
#11 posted 12-04-2021 05:52 PM
Run it over the jointer?
corelz125
#12 posted 12-04-2021 05:54 PM
- noone
This sounds like a reason to start buying some to me.
