ARGH - Hard maple, why do you scorch (tips on routering a juice groove?)
Forum topic by Winny94 posted 11-30-2021 03:16 AM 762 views 0 times favorited 4 replies Add to Favorites Watch
View Winny94's profile
Winny94
125 posts in 1772 days
11-30-2021 03:16 AM
Has anyone found a way to reduce scorching while routering on maple? Ive tried all the normal tips – slower RPMs, increase feed rate, sharp bit, shallow passes, etc., but im still getting some hard to remove scorch marks. Anyone find anything else that works? Maybe hogging out most material w/ a spiral bit?
Failing that, any preferred dremel bits to help remove burns?
View WoodES's profile
WoodES
202 posts in 3021 days
#1 posted 11-30-2021 05:09 AM
Try a “cabinet” https://www.woodcraft.com/products/lynx-2pc-convex-cabinet-scraper-set scraper.
I use it for curved profiles when burn occurs.
View sunnybob's profile
sunnybob
95 posts in 96 days
#2 posted 11-30-2021 05:33 AM
The wood is burning, end of story. Make sure your cutter is sharp and clean, and leave the last pass to be wafer thin.
After that, sandpaper is your friend.
View waho6o9's profile
waho6o9
9130 posts in 3907 days
#3 posted 11-30-2021 01:05 PM
Plunge the corners first then have at it.
https://www.lumberjocks.com/projects/68128
View therealSteveN's profile
therealSteveN
9380 posts in 1905 days
#4 posted 11-30-2021 06:48 PM
I’ve found on Maple, Cherry a lot of your known Burners that speed control is often the issue, what speed ya running at?
Also tends to do the burn when the bit is dull, how many miles does the bit have on it?
What type of bit? 2 flute, three, solid carbide?
If you are good on all of this, then go one floor up, and check waho6o9’s suggestion to do the harder/slower to route corners first, and see if a plunge helps. I personally would still leave that very small amount to clean on a last pass, and do it in 2 to 4 passes, depending on wood density, and depth of desired cut, then do the clean up run. If ya nail it right, it eliminates a lot of sanding.
-- Think safe, be safe
