Trying to create a circle from segments
Forum topic by Tom posted 11-30-2021 02:54 AM 413 views 0 times favorited 6 replies Add to Favorites Watch
View Tom's profile
Tom
184 posts in 2391 days
11-30-2021 02:54 AM
I’ve been asked to make a round serving tray and I’m having problems finding a way to calculate/find a template to print for the “wall” of the tray. What I’m trying to find is a template that’ll let me cut the arched bits out to butt joint/stack them to make the wall of the tray. I’ve found things for woodturning but I’d end up needing 1.5” thick lumber to get a 3/4” thick wall. I’ve put a picture of what I’m trying to do. This is most likely something from a factory with steamed lumber.
View AlaskaGuy's profile
AlaskaGuy
6825 posts in 3640 days
#1 posted 11-30-2021 04:40 AM
Not sure if I follow exactly but look at this.
https://youtu.be/ZTdfmUCGLLc
View Tom's profile
Tom
#2 posted 11-30-2021 06:07 AM
This is what I’m going for – almost that size. I had thought about doing this since it seems to be the best way. My other thought was to make four 20” round panels. One is the base and the other 3 I’d use a router to cut my outer rim and then the leftover smaller circles would be cutting boards or lazy susans.
View jonah's profile
jonah
2273 posts in 4629 days
#3 posted 12-01-2021 12:28 PM
That’s how I would do it – create a panel and cut a ring out of it. Wood movement might be an issue, but it’s small and if dried and milled properly that shouldn’t be too bad.
View Sylvain's profile
Sylvain
1507 posts in 3830 days
#4 posted 12-01-2021 02:26 PM
look here:
https://www.youtube.com/watch?v=1m7ipAw3Mg0
from about 13’30” up to about 21’55” and then from 33’50” to 35’20”
no material waste while doing a curved panel.
It is in a Nordic language but more or less self explanatory.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn (and that is nice)
View Robert's profile
Robert
4827 posts in 2811 days
#5 posted 12-01-2021 02:42 PM
How about a bent lamination? If you have a band saw its really not that hard to do.
View splintergroup's profile
splintergroup
6319 posts in 2553 days
#6 posted 12-01-2021 04:33 PM
I do rings on the router table as described in a frame project
That thin would be kinda scary though! 8^)
