6-15 plug to a L630 recepticle?
Forum topic by Winny94 posted 11-25-2021 06:08 AM 296 views 0 times favorited 10 replies Add to Favorites Watch
View Winny94's profile
Winny94
106 posts in 1722 days
11-25-2021 06:08 AM
Curious if anyone suggests the “best way” to run a 6-15 plug (Delta planer) into a L630 receptacle (installed for PM TS).
Assuming an adapter like this is easiest: https://www.homedepot.com/p/AC-WORKS-Locking-Adapter-NEMA-L6-30P-30-Amp-250-Volt-Locking-Plug-to-NEMA-6-15-20R-15-20-Amp-250-Volt-Female-Connector-ADL630620/303873821
But would it be safe to replace the 6-15 plug with a L630 plug?
10 replies so far
View CaptainKlutz's profile
CaptainKlutz
5013 posts in 2775 days
#1 posted 11-25-2021 06:55 AM
Adapters add another source of failure, and maintenance.
Changing the plug to a locking version with higher current rating is perfectly safe, and the recommended solution.
Note that a typical L6-30 plug is rated for 2HP.
Can not use this plug as it means to disconnect power while motor is operating; IF the motor is larger than 2HP, without potential for damage. This is another reason to switch to a locking style plug, so you can ensure the motor is off when making connection.
Cheers!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
7284 posts in 3774 days
#2 posted 11-25-2021 11:45 AM
I’ve not seen an adapter like that before, learn something every day. But I think the easiest would be to just replace the plug on your planer. I was reading the above response, I think your planer might be 3 HP (mine is) and if the above is true that adapter wouldn’t work.
Winny94
#3 posted 11-25-2021 04:13 PM
I ve not seen an adapter like that before, learn something every day. But I think the easiest would be to just replace the plug on your planer. I was reading the above response, I think your planer might be 3 HP (mine is) and if the above is true that adapter wouldn t work.
- Fred Hargis
My planer is a 2 HP. Odds are I’ll just replace the plug. Just trying to read if there’s any issues running the 10Ga (from the box to the recepticle) into an 8Ga and/or any issues putting the L630 plug on 8Ga.
View Lazyman's profile
Lazyman
8185 posts in 2668 days
#4 posted 11-25-2021 05:57 PM
I am confused. Is the cord on the planer 8ga? If so, make sure that the plug can accept such a thick wire. Or is this a new run from the breaker to the receptacle? Just make sure that the breaker, wire and and receptacle are all rated for the 30 amps.
I am pretty sure that 8 and 10 gauge are fine on a 30 amp 240v circuit unless maybe if it is an exceptionally long run or something. 8 gauge may be overkill
Winny94
#5 posted 11-25-2021 07:29 PM
- Lazyman
Ugh, I misspoke. I meant 12Ga, not 8. (And I need to confirm that before doing anything). I know from break to recepticle is 10Ga 30Amp
#6 posted 11-25-2021 09:36 PM
Don’t be surprised if it’s 14 gauge. Whatever it is, it’ll do for the planer.
View WhyMe's profile
WhyMe
1417 posts in 2842 days
#7 posted 11-27-2021 11:50 PM
Be aware adapters like the one you linked are not UL certified. Be sure to follow manufacturer instructions for power connections. If the motor doesn’t have its own overload protection I highly advise against plugging it into a 30A power source.
Winny94
#8 posted 11-28-2021 12:19 AM
Be aware adapters like the one you linked are not UL certified. Be sure to follow manufacturer instructions for power connections. If the motor doesn t have its own overload protection I highly advise against plugging it into a 30A power source.
- WhyMe
I don’t understand this logic – the tool will pull what it needs. Like plugging a lamp into a 20Amp line.
Lazyman
#9 posted 11-28-2021 12:40 AM
When motors have a problem they can pull more amps than they are supposed to. If the planer doesn’t have a built in 20 amp overload protection it could pull over 30 amps before the breaker trips and burn out the motor, melt the wiring or catch fire.
TopamaxSurvivor
22789 posts in 4957 days
#10 posted 11-28-2021 02:09 AM
- WhyMe
I don t understand this logic – the tool will pull what it needs. Like plugging a lamp into a 20Amp line.
- Winny94
Circuit breakers are overcurrent / short circuit protection. Most hold higher than their rated amps for a significant period of time. Overload protection is specific to the motor it protects and responds much quicker. If you have a piece of wood stuck and stopping the motor in the planer from turning the overloads should trip within a few seconds. Most circuit breakers that will hold the motor starting spike will hold the “overload” long enough to do some damage. Square D and Eaton (Cutler-Hammer) circuit breakers have both thermal and magnetic trips and will trip on a motor overload very quickly but not as fast as the overload protection will. Other brands of circuit breakers have only thermal trips. They will hold an overload for a significant period of time. A short circuit protected by most brands will damage the wire and leave burn marks on the metal item the wire contacted. Square D and Eaton (Cutler-Hammer) circuit breakers’ magnetic trips usually act fast enough there is no visible damage when wire contacts metal making a short circuit. If there is visible damage it is significantly less than the other brands. With that being said, I hope it is clearer than mud ;-) I agree, I would not recommend using a circuit protected at 30 amps on a tool with a 6-15 plug.
