Laguna p flux 3
Forum topic by Allover posted 11-08-2021 02:49 PM 321 views 0 times favorited 11 replies Add to Favorites Watch
View Allover's profile
Allover
5 posts in 78 days
11-08-2021 02:49 PM
I have a laguna p flux 3 DC it is piped into a :
Bandsaw
Tables saw
Thickness sander
Thickness planer
Jointer
I used spiral ducting to keep the airflow, but I am having troubles with my DC. I keep getting large wood chips that filling the heat filter and the container below. This happens even after I clean the hepa filter and clean out the collection bin .
Does anyone have suggestion or reasons this could be happening? Or how to test what the problem could be?
Thanks
11 replies so far
View sunnybob's profile
sunnybob
97 posts in 103 days
#1 posted 11-08-2021 03:16 PM
Are you complaining that your dust filter is actually collecting dust?
Allover
5 posts in 78 days
#2 posted 11-08-2021 03:18 PM
The problem is the hepa filter is filling with wood chips. They are suppose to be separated out to the bin then the filter catches the small particles. But the filter is filling with woodchunks which is not suppose to happen
Allover
5 posts in 78 days
#3 posted 11-08-2021 03:18 PM
sunnybob
#4 posted 11-08-2021 05:43 PM
Sounds like you have something fitted in the wrong order.
Or, the extraction is so fierce its pulling the chips straight across the top of the collector bin.
I’ve Just looked that up and if i have the right one its a 3,000 dollar self contained unit. At that price you need to invoke the suppliers / manufacturers to sort out your problem.
Allover
5 posts in 78 days
#5 posted 11-08-2021 06:54 PM
Yeah that is the one. I hade all the fittings sealed with silicon and in the proper order . Manufacturer told me to fill it with water to find leaks so I am curious if someone has a better idea
sunnybob
#6 posted 11-08-2021 07:00 PM
“filled with silicone” strikes fear in me. can you be totally certain you havent put too much in somewhere it shouldnt be and blocked the flow? If that is a new machine you have every right to insist on a free replacement as it is not fit for service.
I have no actual experience with that machine, so can only give general advice.
Allover
5 posts in 78 days
#7 posted 11-08-2021 07:04 PM
The manufacture recommends sealing all joints with silicon to ensure there is no air leaks. But I’ve had the machine a couple years but just did the hard ducting.
View clagwell's profile
clagwell
400 posts in 1130 days
#8 posted 11-08-2021 08:42 PM
Some questions:
1 – Did the problem start when you added the hard piping or has it always done that?
2 – How full is the barrel when you empty it?
3 – Does you unit have the vortex breaker? (A metal strap like piece that goes across the bottom of the cone. Laguna added it at some point to reduce the tendency of the vortex to drop into the barrel and pick up material that had been previously separated.)
-- Dave, Tippecanoe County, IN --- Is there a corollary to Beranek.s Law that applies to dust collection?
View xedos's profile
xedos
472 posts in 638 days
#9 posted 11-09-2021 03:30 AM
The main problem is the design itself. It uses a “short cyclone” which is generally poor at separating stuff out of the airstream.
That said , chips shouldn’t be an issue. I’d look for a leak(s) and also suspect too high sTatic pressure because of your ducting layout. You’ll need an anemometer to troubleshoot / measure the runs.
View EarlS's profile
EarlS
5014 posts in 3685 days
#10 posted 11-09-2021 12:14 PM
I owned a Laguna C-flux and hated it it. The cyclone is too short, the dust bucket as also too short (and heavy), overall poorly designed. Plus Laguna customer service is TERRIBLE!!!. DO NOT fill your ducts with water to “find the leaks”. What a terrible idea.
What size ducting?
Try running the system with a blast gate partially open at an unused piece of equipment in addition to the blast gate to the piece of equipment you are using. That should lower the static pressure. Also, empty the chip bucket when it gets 1/2 full. If it is too full, the chips are re-entrained in the air and pulled out of the bucket into the filter. Leaks in the system piping won’t result in chips getting pulled into the filter since they need high air flow to remain in the air stream.
View Mike_D_S's profile
Mike_D_S
809 posts in 3552 days
#11 posted 11-09-2021 06:57 PM
If you are getting large wood chips passing through to the filter, then even with the short cyclone there are only a couple of common reasons that would be happening.
1. High bypass for large chips is common when the bin is full. And while I’m sure you probably have checked the bin, did you carefully check the seal for the vacuum line which holds the plastic bag down in the bin. If the vacuum line port on the bottom of the bin is not sealed, the hose is blocked, etc then the bag could be getting sucked up to the top of the bin, essentially making the system work like the bin was “full”.
2. Bypass of large chips is also typical of air leaking into the bin or the cyclone itself. The extra air flow coming up into the bottom of the cyclone disrupts the chip drop out and will result in chips getting sucked into the cyclone outlet.
You can use some incense to smoke test the cyclone with it running to see where air may be getting pulled in.
-- No honey, that's not new, I've had that forever......
