Help finding some examples of 'primitive' bits.
« back to Hand Tools forum
Forum topic by weedeater64 posted 11-04-2021 03:11 PM 379 views 0 times favorited 8 replies Add to Favorites Watch
View weedeater64's profile
weedeater64
81 posts in 1350 days
11-04-2021 03:11 PM
Some time ago I found a page or two about bow/pump drill, and in particular about the bits and various profiles.
I’m having trouble finding anything now.
Is there a name for these non fluted bidirectional bits?
Anyone got a some links detailing various profiles?
8 replies so far
118309 posts in 4916 days
#1 posted 11-04-2021 03:57 PM
Seems to be quite a few if you search Google under “bow drill and bits) using “Images”
weedeater64
#2 posted 11-04-2021 04:10 PM
- a1Jim
Dangit!! I should have known to search images.
Thanks.
View Nubsnstubs's profile
Nubsnstubs
1809 posts in 3069 days
#3 posted 11-04-2021 04:11 PM
Try https://www.tapatalk.com/groups/paleoplanet69529/
It’s probably the best site out there. Lots of different primitive skills forums. ............. Jerry (in Tucson)
weedeater64
#4 posted 11-04-2021 09:29 PM
It s probably the best site out there. Lots of different primitive skills forums. ............. Jerry (in Tucson)
- Nubsnstubs
Just to clarify, I don’t mean primitive as in stone & bone bits.
I mean steel bits that don’t have flutes. Just a shank with a sharpened working end.
I thought I had seen a name other than drill bit being used. Perhaps by someone using a hand drill, just a stick with a metal bit.
View Lazyman's profile
Lazyman
8843 posts in 2727 days
#5 posted 11-05-2021 02:56 AM
Are you talking about spoon bits?
Also, Yankee style push drills have birectional bits without a spiral. Not sure what they are called. Maybe push drill points?
View SMP's profile
SMP
5080 posts in 1245 days
#6 posted 11-05-2021 04:09 AM
- Nubsnstubs
Just to clarify, I don t mean primitive as in stone & bone bits.
I mean steel bits that don t have flutes. Just a shank with a sharpened working end.
- weedeater64
There are a few different types. I remember seeing an old plated brace that a couple of each, including the spoon, spade, and some other one I forgot what was called. Gra mercy does make new spade bits that are good for chair making:
https://toolsforworkingwood.com/store/item/GT-SB.XX
View MikeB_UK's profile
MikeB_UK
840 posts in 2374 days
#7 posted 11-05-2021 10:13 AM
Bidirectional bits
Pin
Shell – probably most common, looks like a pointy gounge, only cuts well at 90 degrees
Spoon
Will work, but designed for single direction
Nose
Centre/batwing
-- Be yourself; everyone else is already taken.
View SMP's profile
SMP
#8 posted 11-05-2021 03:50 PM
Bidirectional bits
Pin
Spoon
- MikeB_UK
That’s right, shell bits are the ones that I usually see with old plated braces. Not to be confused with the actual shells the romans used.
