Adapter for a festool vacuum hose
Forum topic by leftcoaster posted 10-21-2021 05:20 PM 229 views 0 times favorited 4 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
443 posts in 2163 days
10-21-2021 05:20 PM
I need to connect my festool vacuum to a floor machine. It has a dust port of about the same OD as the hose end. Can someone please link to the right adapter for this?
View WilsonLR's profile
WilsonLR
40 posts in 43 days
#1 posted 10-22-2021 01:11 PM
Unless Festool makes an adapter for it’s proprietary hose, you may be able to make one with some schedule 40 PVC and a heat gun/hair dryer. See Youtube for tutorials.
Peachtree Woodworking has a selection of fittings. Ideally, I’d want one that slips over the hose and has a rubber end that slips over your floor machine. I’ve broken a couple ports inserting an adapter inside those plastic ports and the tight fit needed to make a good seal cracked the port. YMMV
https://www.ptreeusa.com/dust_index.html
-- Les
View waho6o9's profile (online now)
waho6o9
9103 posts in 3863 days
#2 posted 10-22-2021 02:11 PM
Are the two Philips screws holding the entire vacuum channel or is it removable so you can insert the hose
directly?
View remdds's profile
remdds
42 posts in 3912 days
#3 posted 10-22-2021 02:33 PM
I had a similar problem. Go to Rockler. They have some smaller rubbery adapter for routers, palm sanders etc.
I was able to find something every time with one or two of their adapters.
leftcoaster
#4 posted 10-22-2021 02:35 PM
directly?
- waho6o9
Good thought but after looking (because I was not as clever) those are what hold the plastic fitting that channels air/dust up from the work.I’m going to see if I can find a plumbing coupling of some kind. I’ve had to do this kind of meatball surgery with other DC connections. If there was ever a bigger time suck (ha ha) I don’t know what it is.
