Hand Planes - Sheared Bolts
« back to Hand Tools forum
Forum topic by TxSurveyor posted 10-20-2021 07:20 PM 357 views 0 times favorited 12 replies Add to Favorites Watch
View TxSurveyor's profile
TxSurveyor
110 posts in 178 days
10-20-2021 07:20 PM
Any tips?
Tote bolt sheared while trying to extract.
Bought this one in this condition. Figured i would drill out the center and try and use extractor.
-- Will, TX -- "You may all go to hell and I will go to Texas" - Davy Crockett
12 replies so far
View SMP's profile
SMP
4966 posts in 1192 days
#1 posted 10-20-2021 07:54 PM
If you have a drill press, try to use that to drill it out. I find that trying by hand then Murphy’s Law will make sure that the hole shifts over and trashed the threads.
View corelz125's profile
corelz125
3886 posts in 2263 days
#2 posted 10-20-2021 08:19 PM
Soak it in penetrating oil as much as you can first. You can try to cut a slot in it to get a screw driver but there’s not a lot of room to work with. Start off with a small drill bit first to get started. That way if it walks a little on You the threads are still good. An easy out will work but you might have to add some heat to it also.
TxSurveyor
#3 posted 10-20-2021 08:38 PM
Thanks!
TxSurveyor
#4 posted 10-22-2021 10:43 AM
Update on Stanley No. 7
Tried soaking in WD40 for 24 hours. Followed with blowtorch. Got it hot enough that when I spit on the plane it boiled. Tried to turn with big pair of pliers. Sheared again.
Tried cutting slot for screw driver using dremel cutoff wheel. Stripped the slot when I tried to turn it.
…. Sigh…..
Guessing I will try and drill it out next. Soaking in 3-in-1 oil now
View Robert's profile
Robert
4792 posts in 2767 days
#5 posted 10-22-2021 11:35 AM
3in1 won’t do any good. WD40 isn’t that good either. Try PB Blaster or the CRC stuff.
I would not use heat. I think you should be very careful heating it could warp the plane.
I would grind off the exposed screw, drill and try an extractor. Try a left hand drill bit sometimes you get lucky the bit grabs the screw and voila! If extractor does t work, you have to re tap it. A bottom tap if you can get one.
Have you determined the thread config for that screw?
View HokieKen's profile
HokieKen
19900 posts in 2425 days
#6 posted 10-22-2021 11:44 AM
Like Robert said, WD40 and 3 in 1 won’t help with these bolts. My favorite is Kroil but PB Blaster works well too. But you need a penetrating oil to get down in there.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
TxSurveyor
#7 posted 10-22-2021 02:03 PM
Robert / Hokieken
I will try one of the products you have recommended. Thanks!
I had that thought about the heat…decided it was worth the risk (mostly because I’m impatient)
I have not determined the thread configuration for the tote screw. Looks like about a #10 screw.
View BlasterStumps's profile (online now)
BlasterStumps
2155 posts in 1726 days
#8 posted 10-22-2021 02:11 PM
soak the plane in Evap-o-rust for a few days. then give it some Kroil
-- "I build for function first, looks second. Most times I never get around to looks." MIke in CO
corelz125
#9 posted 10-22-2021 02:39 PM
Wd 40 makes a penetrating oil also. The regular stuff doesn’t do much. Only need heat at the screw. Doesnt have to be super hot. There’s 12-20 tap and dies available right now if the threads get damaged
HokieKen
#10 posted 10-22-2021 02:46 PM
Your threads are #12-20 Will. Like corelz said, you can buy taps and dies from a couple of places but they are not commonly available. If the plane is strictly a user, you can easily chase them with a 1/4-20 tap and hardware is readily available for those. If you want to keep it original though, you’ll either need to not damage them or buy a 12-20 tap.
Kroil is pretty much unbeatable in my experience for breaking corroded threads. If you don’t have any other penetrating fluid on hand and have to buy something anyway, that’s my recommendation. Do you have a soldering iron? You can heat the bolt without risking warping the casting by holding the tip of a soldering iron to the end of the bolt.
View Don W's profile
Don W
20245 posts in 3854 days
#11 posted 10-23-2021 11:55 AM
…. Sigh…..
- TxSurveyor
Use penetrating oil, but if there is enough to grab, you should heat, and wiggle, heat and wiggle and keep getting it hotter until you feel it start to move. Then keep heating and wiggling until your sure it’s loose enough to come out
TxSurveyor
#12 posted 10-25-2021 12:51 PM
Soaking in PB now. Will update on progress. Thanks for all the tips.
