Hinges for Inset cabinet door w/ “face frame”
Forum topic by Fulli posted 10-19-2021 11:54 AM 450 views 0 times favorited 6 replies Add to Favorites Watch
View Fulli's profile
Fulli
2 posts in 44 days
10-19-2021 11:54 AM
Hi all. I built this faux card catalog cabinet for my wife and I’m a bit confused on how to hinge the door. The door is inset with the “drawer” fronts mounted to it. There is a 1/4” over hang all the way around. So essentially I need a solution for an inset door with a 1/4” overhang “face frame” on a frameless cabinet. Also I’d like the hinges to be hidden if I can help it. Thanks for your help.!
View stripit's profile
stripit
152 posts in 3325 days
#1 posted 10-19-2021 12:18 PM
Hi. believe they arecalled Eropean hinges, total hidden.
-- Joel, People ask what I make. I tell them I make sawdust, and now and then a nice box or frame,or clock, or lamp pops out.
View waho6o9's profile
waho6o9
9096 posts in 3859 days
#2 posted 10-19-2021 01:01 PM
Yup European hinges.
I had to add a block to the partition for functionality. Practice on a mocked up cabinet if you can. There are hinges with different angled openings, maybe get one that opens straight out and then swings open.
Welcome to LumberJocks Fulli!
View Jared_S's profile
Jared_S
489 posts in 1241 days
#3 posted 10-19-2021 01:19 PM
You want rabbeted door hinges.
View LeeRoyMan's profile
LeeRoyMan
2236 posts in 1009 days
#4 posted 10-19-2021 02:09 PM
Your best shot would be a Blum 170 degree hinge. (They call it a special application hinge)
Straight arm with an 18 mm plate
or
cranked arm with a 9mm plate
If it does work, the door may still only open to 90 degrees or so.
You’re still going to have to make a mock up to see if it works.
I don’t think the rabbited door hinge will work with your inset.
Panels on the front will hit the face frame and the door won’t open. (I think) could be wrong.
Fulli
2 posts in 44 days
#5 posted 10-19-2021 02:18 PM
Thanks for your replies. I actually found these in the shop this morning I’m going to do a mock up first to get it right
View jsvenson11's profile
jsvenson11
23 posts in 1390 days
#6 posted 11-09-2021 03:49 AM
Either the rabbet hinges or the blum inset hinges will work for this. Just did something very similar using blum inset hinges
