double sided tape or glue with paper
« back to Woodturning forum
Forum topic by Ken Olsen posted 10-16-2021 04:25 PM 491 views 0 times favorited 9 replies Add to Favorites Watch
View Ken Olsen's profile
Ken Olsen
34 posts in 428 days
10-16-2021 04:25 PM
I have to tuen a bottom for a salad bowl I’m making so i have to round a maple blank and cut into it a recess to hold my my nova chuck jaws since i cant use wood screws i was considering double sided tape which seems easy to use and the glue and paper trick which i am not familiar with, since i have to cut a 1/4 inch depth into maple im concerned that the whole thing will fly off and hit my wife car. Any suggestions would be appreciated.
I tried using the flat expanadble jaws for the nova chuck but the bottom is 11 1/2 inches wide and it does not open enough
-- My daughter came into the garge when she was small and said I know what your making mom told me Its a Mess
9 replies so far
View JohnDon's profile
JohnDon
200 posts in 2452 days
#1 posted 10-16-2021 06:51 PM
Move the car! :)
View Nubsnstubs's profile
Nubsnstubs
1808 posts in 3012 days
#2 posted 10-16-2021 09:28 PM
Get Jerry’s Tail Stock Steady. It’ll hold anything you put up there. See my signature. ........... Jerry (in Tucson)
View Aj2's profile
Aj2
4129 posts in 3080 days
#3 posted 10-17-2021 05:26 AM
I agree with John. Talk to the wife about parking her car in your woodshop.
-- Aj
View LesB's profile
LesB
3136 posts in 4725 days
#4 posted 10-17-2021 08:22 PM
I would not trust double sided tape for this purpose.
The glue method involves making a mounting plate, usually 3/4” plywood, screwed to a face plate. Then you apply wood glue to both the plywood surface and the bowl blank. With a piece of newspaper or brown paper bag between the two parts clamp them together, making sure they are as close to centered on the face plate center as possible. Wait 24 hours and do your turning. When finished take a broad chisel (1” or wider) and cleave them apart at the glue joint. The paper will give way before the wood and all you have to do is scrape and sand the glue and paper off the bowl.
Because this is a bowl you can always screw the face plate directly into the blank on the side that will eventually be the inside of the bowl. The holes will be removed when you turn that side. Completely turn the bottom (including sanding) and add either a mortise or a tenon for mounting the bowl on your chuck to finish the inside.
If you have a router you can try a method I use for mounting rough blanks on my chuck. I have a blog you can check out here: https://www.lumberjocks.com/LesB/blog
-- Les B, Oregon
View MrUnix's profile
MrUnix
8799 posts in 3481 days
#5 posted 10-17-2021 08:47 PM
Did your chuck come with a “woodworm” screw?
Ken Olsen
#6 posted 10-17-2021 09:45 PM
Thanks everyone I’m going to try the block paper and glue to the comment get my wife’s car out of my shop that didn’t go over to well. l
Ken Olsen
#7 posted 10-17-2021 09:48 PM
View TheDane's profile
TheDane
6017 posts in 4945 days
#8 posted 10-17-2021 10:54 PM
I would not use plywood for a glue block. If it delaminates, which it can easily do, you could wind up with your bowl slamming into your faceshield. Use a solid wood block (preferably hard wood).
View OSU55's profile
OSU55
2893 posts in 3272 days
#9 posted 10-17-2021 11:20 PM
Here is a good video from Lyle Jamieson on glue block prep. He has another for bottom prep. Thick CA glue is my preference, particularly since I’m usually turning wet wood. I typically put a tenon on the glue block and use a chuck. I only use glue blocks if the wood is not thick enough for a tenon. Rarely use a mortice.
https://youtube.com/watch?v=y8b35iq4LTA&feature=share
