Purpleheart and Maple Bowl
« back to Woodturning forum
Forum topic by adot45 posted 10-16-2021 10:49 AM 463 views 0 times favorited 8 replies Add to Favorites Watch
View adot45's profile
adot45
427 posts in 1906 days
10-16-2021 10:49 AM
Wanted to try this wood combination, i like it. I’ve only got a couple of coats of bowl finish on so far, that’s why it’s still on the glue block.
I use carbide because I never learned to sharpen HSS tools. Does a skew have to be sharpened on a wheel or could I sharpen it on a Work Sharp?
-- “Often wrong but never in doubt”. Dave in WV.
8 replies so far
View TheDane's profile (online now)
TheDane
6017 posts in 4945 days
#1 posted 10-16-2021 12:09 PM
You certainly can sharpen skews (and other HSS tools) on a Work Sharp … I have done it when my grinder motor went south. As a matter of fact, Work Sharp used to make attachments to grind HSS gouges, etc.
View Dave Polaschek's profile
Dave Polaschek
8795 posts in 1864 days
#2 posted 10-16-2021 12:18 PM
I sharpen my skew on the same stones I use to sharpen my planes and chisels. If you can sharpen a chisel, you can sharpen a skew.
Nice combination of woods!
-- Dave - Santa Fe
adot45
#3 posted 10-16-2021 12:21 PM
Thanks Dane and Dave, I’d like to learn to sharpen the few HSS tools that I Do use. The skews and a scraper or two.
View Ken Olsen's profile
Ken Olsen
34 posts in 428 days
#4 posted 10-16-2021 04:27 PM
great looking bowl what bowl finish did you use? sanded to what grit? thanks
-- My daughter came into the garge when she was small and said I know what your making mom told me Its a Mess
adot45
#5 posted 10-16-2021 04:39 PM
- KCOlsen
Thanks , I use General Finishes “Wood Bowl Finish” put on with a tee shirt. I sand to at least 400 sometimes 600.
View j1440's profile
j1440
23 posts in 1001 days
#6 posted 10-16-2021 04:57 PM
A beautiful bowl—-this should show those that put down carbide tools what a great job can be done with them.
-- Jim, Kingman, Az
View Nubsnstubs's profile
Nubsnstubs
1808 posts in 3012 days
#7 posted 10-16-2021 09:36 PM
I don’t see how carbide can not be considered a good turning tool. I have done some turnings that were videoed with the wood shavings looking like wisps of smoke coming off my piece and very slowly sinking down to the ground. I can’t make those cuts with a Thompson gouge (not badmouthing his gouges), they are the only ones I have, but I just can’t make the shavings that thin.
Good job on the Hollow form, Dave. Is that a foot or is the tenon still on it? ........... Jerry (in Tucson)
adot45
#8 posted 10-16-2021 10:14 PM
Hi Jerry, you can’t see much of the foot but the seam of the glue joint is the dark foot and the plywood.
