Hanging Jet air filter 1100b
Forum topic by yasinh posted 10-16-2021 02:44 AM 305 views 0 times favorited 4 replies Add to Favorites Watch
View yasinh's profile
yasinh
9 posts in 94 days
10-16-2021 02:44 AM
Hey Everyone,
I recently bought a new air filter jet 110b. I’m planning to hang it during the weekend. Instead of hanging down the ceiling joist I want to put it on top of the ceiling joist. I’m planning to add 2×4 perpendicular to the joist and add filter on top of it. Would this be a good setup? Attaching a picture of my garage.
View MrRon's profile
MrRon
6205 posts in 4526 days
#1 posted 10-16-2021 04:01 AM
That’el work.
View dbw's profile
dbw
635 posts in 2919 days
#2 posted 10-16-2021 04:23 AM
I don’t see why not.
-- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy.
View northwoodsman's profile
northwoodsman
681 posts in 5028 days
#3 posted 10-16-2021 07:41 PM
It may not be as effective. This is a relatively high volume unit as long as it can get a good airflow coming into it and exiting out of it. Any disruption of airflow on the input side will reduce flow, any thing on the back side that restricts airflow could deflect it back towards the input side thus reducing the effectiveness if that clean air is sucked back in. Also any obstructions on the input side that disrupt airflow may cause the particles to fall out of suspension since they are slightly heavier than air. If you use the joists for wood storage or if it partially floored as it looks in your photo it will do a superb job of keeping the area between your rafters and your ceiling joists clean. You will be changing the pre-filter often and cleaning the main filter often. Make sure they are easy to get to. It’s a great unit. I love the remote speed control and timer. I let it run for an hour or two after I leave the work area to help eliminate dust in the shop.
-- NorthWoodsMan
View WoodenDreams's profile
WoodenDreams
1448 posts in 1193 days
#4 posted 10-16-2021 08:42 PM
Your Jet air filtration unit is a nice unit. As northwoodsman notes. Is there through air circulation to rotate air through the shop. 2nd; where you plan on putting the unit, is it in reach to vacuum out or clean the filter. And or change the filter. I use a vacuum hose to clean my filters when I’m sanding a lot. Differs the cost of replacing the filters.
