Saw small logs like a mill
Forum topic by birdman posted 10-12-2021 02:58 PM 1020 views 0 times favorited 16 replies Add to Favorites Watch
View birdman's profile
birdman
33 posts in 4992 days
10-12-2021 02:58 PM
Topic tags/keywords: chainsaw logs
Anyone have a jig to at least hold a log for sawing with a 16” chainsaw?
-- DavidP - still count on my fingers and toes - not for math, just inventory!
16 replies so far
View Ruscal's profile
Ruscal
148 posts in 637 days
#1 posted 10-12-2021 04:44 PM
Google “Granberg Alaskan chain saw mill”. I think they start at 20” bars and bigger though. If the log isn’t too long resawing on a bandsaw would work better.
-- Have a hobby? You should have a business.
View therealSteveN's profile
therealSteveN
9990 posts in 2033 days
#2 posted 10-12-2021 05:54 PM
Yes, if manageable for size a bandsaw will win out easily. Plus a much smaller kerf = less wasted wood.
-- Think safe, be safe
View JCamp's profile
JCamp
1740 posts in 2010 days
#3 posted 10-12-2021 06:05 PM
Alaskan sawmill. You can buy the knock off versions on eBay and Amazon. I have one. The cheapness leaves a lot to be desired. The brand name I imagine is much better. They make one that only attaches in the back of the bar that in theory you could use along one side of a log and then switch and run on the other side. If you aren’t needing anything real precise you could free hand too. Big discussion on chainsaw mills is saw size. I have a husqvarna 455 and many say it’s to small. I’d think almost any saw could do it if you have a sharp chain and go slow. Bars and chains are fairly inexpensive so you might invest in a bigger bar.
-- Whatsoever thy hand findeth to do, do it with all thy might
JCamp
#4 posted 10-12-2021 06:07 PM
This is the one I’d suggest for a smaller saw. I think the attachment takes up about 2 inches which would leave a 14inch cut
https://www.amazon.com/Granberg-Chain-Mill-Model-G777/dp/B000AMFY90/ref=asc_df_B000AMFY90?tag=bingshoppinga-20&linkCode=df0&hvadid=80401840125272&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=m&hvlocint=&hvlocphy=&hvtargid=pla-4584001418458181&psc=1
birdman
#5 posted 10-12-2021 09:19 PM
Thanks guys.
Wow the knockoff is really cheap! Probably worth buying just for safety’s sake since I don’t have a band saw.
A few years ago I began having good luck finding cherry oak and other logs or being on the spot when unfortunate trees were felled. So I have some logs that are dry and ready.
JCamp
#6 posted 10-13-2021 12:12 AM
I could be wrong but I’m pretty sure if you contact wood Mizer they keep a list of ppl that have their mills. They might be able to help you find someone to cut them up with a bandsaw mill. Nothing wrong with the chainsaw on it’s just a lot of work
View gtrgeo's profile
gtrgeo
236 posts in 1889 days
#7 posted 10-13-2021 02:54 AM
If you are just looking to try it out on the cheap you can do like this video.
I did something similar with an 18” saw, a couple of pieces of all thread, a scrap of plywood, and some hardwood blocks. You may need to drill a couple of holes through the bar which is very easy as it is just mild steel.
It worked fairly well to cut up a maple tree we took down a couple years back. Just remember to mount your chainsaw with the bar towards the bottom when you are running it or your oiler may not work.
View ibewjon's profile
ibewjon
2937 posts in 4252 days
#8 posted 10-13-2021 12:50 PM
I purchased the Logosol Timberjig at the woodworking show years ago and have been happy with it’s operation and results.
View Lazyman's profile
Lazyman
9602 posts in 2847 days
#9 posted 10-13-2021 03:07 PM
If it is just a couple of relatively short logs, John Heisz’s simple vertical chainsaw mill might worth a look.
JCamp
#10 posted 10-13-2021 07:53 PM
Norwood also makes a “mill” set up for a chainsaw called a porta mill. I don’t know anything about if but it’s a slick looking set up
View Putttn's profile
Putttn
153 posts in 3737 days
#11 posted 01-13-2022 01:13 PM
Lil Ripper is what i have and works well
-- Bill eastern Washington Home of beloved ZAGS
View HokieKen's profile
HokieKen
21714 posts in 2598 days
#12 posted 01-13-2022 02:46 PM
I have one of the knock off Alaskan mills. It gets the job done. But you’ll be sore the next morning ;-)
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View KelleyCrafts's profile
KelleyCrafts
5317 posts in 2198 days
#13 posted 01-13-2022 08:37 PM
It’s a young man’s game for sure but totally doable.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
JCamp
#14 posted 01-14-2022 03:00 AM
That’s some good looking lumber
View bigblockyeti's profile
bigblockyeti
8530 posts in 3180 days
#15 posted 01-14-2022 04:11 PM
I bought “The Beam Machine” from amazon for $47.98 in 6/13 and it’s a bit sloppy on a BORG 2×4, with shims hot glued to the inside of the channel, it worked better but far from great. I have a reasonably powerful 54cc saw (not powerful but good for a 54cc saw) and I dedicated a chain for ripping only, ground the chisels at 0° and filed the rakers down to let it cut beautifully but very, very slow. The first log I milled was a ~Ø13” white pine and it burned through a tank of gas in two out of four cuts turning it into a cant. I probably mill less than a dozen logs total with that and I’ve since bought a Wood-Mizer that is much quicker. I also have a 20” bandsaw that I’ve milled several logs on but it gets tiresome trying to manhandle 400+lb logs and keep them tight to the fence at the same time.
-- “I never in my life thought I would have to say this, but the proper role of government is not to fund the distribution of crack pipes,” Lauren Boebert
