How To Fix This....suggestions?
« back to Woodturning forum
Forum topic by adot45 posted 10-06-2021 02:23 PM 625 views 0 times favorited 5 replies Add to Favorites Watch
View adot45's profile
adot45
444 posts in 1909 days
10-06-2021 02:23 PM
Here is what I ended up with by not paying close enough attention to the instructions i guess…
If I glue the top on so I can turn the body to it’s final shape, how do I finish the lip?
Or try doing something with the lip, glue it on and then try to finish the lip?
-- “Often wrong but never in doubt”. Dave in WV.
5 replies so far
View Dave Polaschek's profile
Dave Polaschek
8805 posts in 1867 days
#1 posted 10-06-2021 07:18 PM
How about just moving the tail stock in to hold the lid on with a live-center, kinda like a jam-chuck? Should hold well enough that you can get the shape of both pretty dang close, then pull off the lid to do any final work on that.
-- Dave - Santa Fe
adot45
#2 posted 10-06-2021 07:58 PM
Hi Dave Yep that’s a good idea. Any variation on that would be good…..so I’m staring at it and before I knew it I had it glued. If I make this shape again I think I would use two glue blocks to make the rings and then slap em together. Anyway I was anxious to do the final outside shape.
View Kerux2's profile
Kerux2
575 posts in 3017 days
#3 posted 10-06-2021 07:58 PM
Well, at worse… you’ve got mighty pretty bowl.
-- Hey I'm Dyslexic! I don't have all day to check and re-check forum post.
adot45
#4 posted 10-06-2021 09:08 PM
There ya go, there’s always a bright side…
adot45
#5 posted 10-07-2021 04:05 PM
It turns out that this was a non issue. I just shaped the lip about how I thought then just kept cutting the angle in and the top fell right in. Done deal.
