SuperMax 19-38 Drum Sander won't start
Forum topic by hairy posted 09-26-2021 06:14 PM 223 views 0 times favorited 13 replies Add to Favorites Watch
View hairy's profile
hairy
3321 posts in 4779 days
09-26-2021 06:14 PM
I contacted customer service, but don’t expect an answer today.
Voltage to the tool is NOT the problem, but that’s as far as the manual goes with this problem.
No indication of any kind. This has 2 motors, 1 for the drum and 1 for the feed roller.
Thanks for your help.
-- there's someone in my head but it's not me...
13 replies so far
View Foghorn's profile
Foghorn
1299 posts in 633 days
#1 posted 09-26-2021 07:16 PM
My Delta has a reset button. Red and about 1/8” diameter.
-- Darrel
hairy
#2 posted 09-26-2021 08:05 PM
Thanks! This doesn’t have it.
View Knockonit's profile
Knockonit
985 posts in 1449 days
#3 posted 09-26-2021 08:38 PM
well now, each has an off and on button on mine, i can have the roller feed running and not the drum, does any of it work
-- Living the dream
View splintergroup's profile
splintergroup
5877 posts in 2469 days
#4 posted 09-26-2021 08:46 PM
Yep, need to know if it is all dead (both motors) or just one of them.
hairy
#5 posted 09-26-2021 08:49 PM
2 motors, each has it’s own switch. Nothing works.
View therealSteveN's profile
therealSteveN
8900 posts in 1821 days
#6 posted 09-26-2021 09:07 PM
You’ve plugged it into a different outlet to ensure it’s not just an electrical source problem? Seems like 2 separate motors both deciding to go tits up at the same time is really bad luck. My 19/38 has both motors as completely separate units, not like they have anything shared. I’m thinking it’s not the tool, but the electric source. Breaker, etc etc.
-- Think safe, be safe
hairy
#7 posted 09-26-2021 09:11 PM
Everything I plug into that outlet works.
It doesn’t work in other outlets.
It’s not a power problem. I was hoping that someone who owns this machine had the same problem.
splintergroup
#8 posted 09-26-2021 09:12 PM
I’m only “intimately” familliar with the Performaxe’s, but there seems to be some common design elements.
(Speaking to a Performax so ignore if it doesn’t apply)
Assuming there is power to the terminal end of the main supply cord:
The main power enters the control box where it splits to the drum motor (plugged into a socket on the back of the box) and to the speed control for the conveyor motor.
The point where the main cord splits off consists of “Faston” type connectors which really are a bit underrated for the current. Could be one has slipped off or is otherwise cooked and not making connection anymore.
The box can be opened for inspection, but requires the conveyor motor be disconnected from the drive roller, Access is from below, a standard set screw. Loose that and remove the 4 hex head screws on opposite corners of the box. Slide the conveyor motor off the drive roller with the box cover.
Do not turn the motor or roller or aligning the shaft flat that the set screw locks down on can be a real bugger.
hairy
#9 posted 09-26-2021 09:39 PM
I’m back in business, thanks for all the help.
The power cord was the problem. That’s why it wouldn’t work, but other tools plugged into the outlet did work.
The bad part was near the plug, I cut that off and rewired the plug. Working good, now just a little shorter.
Thank you all !
hairy
#10 posted 09-26-2021 09:41 PM
And yes, I feel really stoooooooooooooooooooooooooooooooopid right about now.
View ibewjon's profile
ibewjon
2652 posts in 4040 days
#11 posted 09-26-2021 11:09 PM
Go with the feeling…. Don’t sweat it. We all have brain farts.
hairy
#12 posted 09-26-2021 11:14 PM
Thank you!
I should have stayed in bed today. I started off by getting a splinter under the fingernail of my right index finger. I’ve been bumping it into everything.
And it went downhill from there.
I’m going to find out if I can watch tv without screwing that up.
therealSteveN
#13 posted 09-27-2021 03:47 AM
hairy, glad ya got it working, makes for an expensive boat anchor. :-)
