Can't tell the difference between these two General Finishes
Forum topic by BiologistAngler posted 09-23-2021 09:23 PM 246 views 0 times favorited 6 replies Add to Favorites Watch
View BiologistAngler's profile
BiologistAngler
36 posts in 993 days
09-23-2021 09:23 PM
This is the finish I normally like to use: https://www.woodcraft.com/products/arm-r-seal-top-coat-satin-pint
It is labeled simply “oil-based arm-r-seal satin”
I don’t understand what is different about this one: https://www.woodcraft.com/products/arm-r-seal-top-coat-satin-quart
It is labeled “oil and urethane topcoat”
The first link of the “oil-based arm-r-seal satin” is a urethane also, isn’t it?
I’m asking because I ordered a gallon of this from Home Depot https://www.homedepot.com/p/General-Finishes-1-gal-Satin-Arm-R-Seal-Urethane-Interior-Topcoat-GF-ASGA/305227228
I honestly don’t know which it is, because it uses the picture of the first one (the oil-based arm-r-seal satin I normally use). but it labels it “Satin Arm-R-Seal Urethane Interior Topcoat” LOL so I have no idea which it really is and what the differences is between these two are. All I know is that the normal arm-r-seal in satin is the kind I prefer, NOT the “topcoat” type. By “topcoat” I’m assuming it is just a normal polyurethane, which I don’t like to use because it gives surfaces a plastic like look. I’m hoping someone can clear this all up, because I’m super confused.
View northwoodsman's profile
northwoodsman
673 posts in 4989 days
#1 posted 09-23-2021 11:37 PM
One is a pint, one is a quart. Perhaps they are the same items but Woodcraft didn’t update the image or the spec online yet? I would go to General Finishes website and investigate using the UPC ’s or GTIN.
-- NorthWoodsMan
View Rich's profile
Rich
7456 posts in 1832 days
#2 posted 09-24-2021 12:01 AM
It’s all the same stuff. If it says Arm-R-Seal, that’s what it is, regardless of the label design. There are not different versions of Arm-R-Seal other than the sheen.
They change their labels occasionally. In fact if you want, you can even go vote for your favorites on their web site.
View CaptainKlutz's profile
CaptainKlutz
4898 posts in 2737 days
#3 posted 09-24-2021 06:59 AM
+1 same stuff different label.
FWIW – Couple of comments as you move to larger project or volumes of Arm-R-Seal (ARS):
- Satin finish is achieved by adding flattening agent to gloss version of ARS. Use of flattening agents in thick top coat can make finish cloudy, and obscure grain. If you want a thick film build applied by wiping on many layers of ARS; it is recommended that you use gloss version for all, but top 1~2 coats.
- The flattening agent settles to bottom of can quite easily. IME is more noticeable in gallon cans. Have seen material settling on bottom in as little as 15 minutes. So remember to mix/stir any satin ARS top coat often, or you will find glossy spots on project. For same reason, work quick and do not re-touch large panels or you might see streaks in sheen level.
If need satin finish on a project that requires a gallon of finish, and the project has large panels; normally use spray gun with satin lacquer, conversion vanish, or 2K poly instead. Large panel satin sheen finishes require more attention to application method, to enable covering surfaces quickly, evenly, with zero touch up.
Best Luck!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
View dbw's profile
dbw
626 posts in 2879 days
#4 posted 09-24-2021 11:48 AM
It s all the same stuff. If it says Arm-R-Seal, that s what it is, regardless of the label design. There are not different versions of Arm-R-Seal other than the sheen.
- Rich
+1
-- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy.
View bondogaposis's profile
bondogaposis
6046 posts in 3594 days
#5 posted 09-24-2021 01:30 PM
Same thing, different size.
-- Bondo Gaposis
View Rich's profile
Rich
#6 posted 09-24-2021 01:35 PM
- CaptainKlutz
Technically, they are called flatting agents.
I’ve seen that gloss/satin schedule mentioned before. I’ve done it both ways and found no perceptible difference, but without quantifying it, it’s just a subjective observation, so YMMV.
I don’t think of Arm-R-Seal as something I’d use to build that thick of a film anyway.
