Forum topic by SMP | posted 09-23-2021 06:10 PM | 520 views | 0 times favorited | 5 replies | ![]() |
I need a bunch of full extension drawer slides. My local lumberyard carries KV and Fulterer in soft close full extension side mount drawer slides. The Fulterers are about $7 a piece cheaper than KV for the 24” slides I need for pantry drawers. Given that I need quite a few slides I am hoping to save some money. But how do the Fulterers stack up against the KV? Anybody used both and can compare? Especially over time? thanks! |
5 replies so far
#1 posted 09-23-2021 09:27 PM |
https://www.lumberjocks.com/topics/311116 This is a thread I started a year ago, they have since showed up and are working fine. Long story short. Fulterer was more expensive so I only bought one of them and 7 of the Hettich. They are both basically the same and work fine. I considered KV as well but couldnt find the size I needed. |
#2 posted 09-23-2021 10:00 PM |
I’ve replaced most of my kitchen cabinet shelves with drawers and have used the KV8400 series slides. The drawers are opened and closed daily and some are large and loaded with can goods, etc. I’ve never had a problem. I only buy the KVs made in the USA. KV came out with less expensive (made offshore) slides to offer a lower price point and compete with cheaper brands. I don’t know anything about Fulterer slides. |
#3 posted 09-23-2021 11:09 PM |
Never heard of Fulterer’s so can’t say. KV’s work well. What I was here to say is a call back is the worst thing to happen on an otherwise happy job, and slides/hardware can be a frequent reason. You have to return to a job you will not be paid for, and usually have to fork out more money for product, instead of just putting in good product to begin with. No value in junk parts. -- Think safe, be safe |
#4 posted 09-23-2021 11:17 PM |
Thanks all. Yeah I also bought some at either Lowes or Home Depot. The slides themselves work fine. However, the “soft close” mechanism gets stuck sometimes and keeps the drawer from closing. you have to pull the lever and completely remove the slide/drawer. Reach in and push the little “pin” in the soft close mechanism. Kind of a pain, and happens once every few months. |
#5 posted 09-24-2021 06:02 PM |
I have used both. And several others. The main discerning difference after cost, is in the bearing carrier materials and the number of bearings. One is a plastic bearing carrier with fewer bearings and the another is a metal carrier with more bearings. Most plastics might dry up and wear out after a decade or so. For a while, with the metal carriers, there was a failure mode where you could strip the bearings when inserting the drawer box member into the cabinet member. They, and most of their counterparts are pretty well set as for standards of construction and reliability. If it is my choice and all other considerations are equal, I am buying the one with the metal bearing carrier and the higher bearing count. Also, I am not a fan of soft closing side mount guides in general. My $0.02 -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS |
Forum | Topics |
Woodworking Skill Share
13540 |
Woodturning
3006 |
Woodcarving
617 |
Scrollsawing
436 |
Joinery
2073 |
Finishing
6705 |
8185 |
34170 |
CNC Woodworking
384 |
Hand Tools
6767 |
Jigs & Fixtures
1919 |
Wood & Lumber
7611 |
1696 |
Focus on the Workspace
2747 |
1295 |
Woodworking Trade & Swap
5574 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9897 |
