How to Install Foldable Lid Support Hinge Stays
Forum topic by Rooster57 posted 09-22-2021 02:33 PM 274 views 0 times favorited 1 reply Add to Favorites Watch
View Rooster57's profile
Rooster57
1 post in 300 days
09-22-2021 02:33 PM
Topic tags/keywords: question
Could someone please provide a simple set of instruction to fit a pair of Foldable Lid Support Hinge Stays to a large blanket box? I want the lid to be leaning back slightly when fully open and the Stay should not prevent the lid from fully closing. There are numerous Stays for sale but none of the web sites provide standard installation instructions.
-- David, Queensland, Australia, http://WoodworkerDavid.com
1 reply so far
View bilyo's profile
bilyo
1406 posts in 2342 days
#1 posted 09-22-2021 03:52 PM
Your post is very timely. I just struggled through the same process while restoring an old oak secretary. From your picture, It looks about right. But, I assume from your question, something isn’t working properly. The end pivot points need to be equidistant from the hinge axis. That distance will depend on the angle you want the lid to be when open. Just make sure that the distance is the same both ways. Also, you may have to adjust for offsets at each end based on the shape and size of the mounting brackets. It may be easiest to draw yourself a precise diagram. It also may help to make a model with a couple of scrap pieces hinged together to test your measurements before drilling into your box and lid.
I worked mine out with simple geometry on paper. I can explain that if you need me to but it will take a lengthy explanation. Someone else may be able to do it mathematically.
