Benchtop Jointer then finish with handplane
Forum topic by Nap3p posted 09-18-2021 08:24 PM 439 views 0 times favorited 16 replies Add to Favorites Watch
View Nap3p's profile
Nap3p
26 posts in 429 days
09-18-2021 08:24 PM
First off I’ve searched and read tons of threads related to benchtop jointers and their limitations. So please don’t just recommend a floor model (I would buy one if I had the space).
I’m wondering if a benchtop jointer could be useful for “rough jointing” followed by a No. 7 to fine tune/finish? Or is a benchtop more likely to worsen twist etc?
Board size would be 48” and under if that helps.
My current process is all handplanes for milling and it’d be nice to outsource some of the initial grunt work to a machine. There’s a well cared for delta jt160 near me for $90 that might be worth giving this idea a try. I would of course see how off the table and fence were before buying too.
16 replies so far
View SMP's profile
SMP
4830 posts in 1148 days
#1 posted 09-18-2021 09:47 PM
I have a benchtop jointer and have never needed anything more, since I usually only use 4/4, 6/4, or 8/4 stock. I usually have to do some hand planing before the jointer, so sometimes I will just use a hand plane to fet one side “flattish” to ride my tablesaw fence, then use the TS to “joint” the opposite side, flip over and trim to parallel sides.
View Loren's profile
11270 posts in 4891 days
#2 posted 09-18-2021 09:47 PM
I think you have a good plan. Your skill with a hand plane will certainly develop.
Nap3p
#3 posted 09-18-2021 10:19 PM
- Nap3p
I’m also more interested in how it would do face jointing. I can edge joint with a track saw followed by a table saw.
View SMP's profile
SMP
#4 posted 09-18-2021 11:30 PM
- Nap3p
depends on the board. Depend on if its bowed or has twist etc.
View nicksmurf111's profile
nicksmurf111
386 posts in 2693 days
#5 posted 09-19-2021 01:28 AM
I think I’d find a jt160 to be underpowered. If I needed a benchtop, I’d probably mount an 6” iron jointer beside a motor and provide an adequate dust port. Only negative is that putting such a contraption away would be a chore, but I think I’ve seen people do it.
-- Nicholas
View corelz125's profile
corelz125
3731 posts in 2219 days
#6 posted 09-19-2021 03:37 AM
I have the shop fox spiral head 6” bench top jointer. When the board comes off of it, it’s ready no need for hand jointing
View OldBull's profile
OldBull
516 posts in 538 days
#7 posted 09-19-2021 05:57 PM
I am not sure about others but my wahuda fence goes out of alignment just touching it, it is crap. I made the mistake of mounting it on a roll around cart and my floor is pretty rough. I spend an hour re-adjusting every time I use it. If I was sitting there with 500 cash in my hand and know what I know now I would purchase a floor model.
View controlfreak's profile
controlfreak
2890 posts in 844 days
#8 posted 09-19-2021 10:09 PM
If I could just get my hand jointing skills to be perfect via planes I could free up so much space in the tiny shop. I must admit I am thinking about a power tool wing add on to the existing shop.
Nap3p
#9 posted 09-19-2021 10:23 PM
Well, I pulled the trigger on it for $80. Ordered a set of new blades but the tables were fine and fence easily adjusted to 90 (and has stayed so far).
Cleaned up and waxed the tables as well as adjusted the blades. Ran some pine and mahogany and it did a nice job giving me a flat face. Easily touched up with a No 7 and smoother.
I’ll try and update this thread later this week after the new blades come and I’ve used it a bit more.
So far seems to be worth the $80…given how loud it is you might say it’s a “screaming” deal.
View tvrgeek's profile
tvrgeek
2285 posts in 2892 days
#10 posted 09-19-2021 10:28 PM
I tried one and it scared me. I used my TS with a sacrificial fence and jointer blade until I bought a floor stander.
View DevinT's profile
DevinT
1917 posts in 209 days
#11 posted 09-21-2021 01:16 AM
I can recommend the Cutech jointer. It was a pleasure to use and the results were more than acceptable. Then there’s the matter of the price tag … very affordable in my opinion at around $500 if memory serves.
-- Devin, SF, CA
corelz125
#12 posted 09-21-2021 01:36 AM
The cutech is a 6” with straight knives?
DevinT
#13 posted 09-21-2021 02:33 AM
Spiral Cutterhead Benchtop Jointer
6” or 8”
No straight knives. Did you need straight knives?
EDIT: The one that I have used was the 6” and I got the price wrong, it’s $289. I’ve also used their planer (which is $579 which is what I was recalling for price)
-- Devin, SF, CA
corelz125
#14 posted 09-21-2021 04:40 PM
The spiral head machines are more affordable now
Nap3p
#15 posted 09-30-2021 04:20 AM
Just to update this for someone who stumbles across it in the future. I’ve found the machine to be a helpful addition to the shop. Would I buy a new one? No, but for $80 it was well worth it.
As soon as I have the room I’ll be getting a real jointer as this has shown me how nice and convenient that would be. In the meantime, easily get by using the bench top and fine tuning with hand planes.
