Unknown Table Saw Jig
Forum topic by Tgobbs posted 09-15-2021 08:38 PM 542 views 0 times favorited 6 replies Add to Favorites Watch
View Tgobbs's profile
Tgobbs
3 posts in 1867 days
09-15-2021 08:38 PM
Topic tags/keywords: jig
I built this jig some years ago and cannot remember it’s function. It does not straddle my table saw fence. Would appreciate someone to identify it. See photo.
-- Tom, Ashlanland, VA
View StevoWevo's profile
StevoWevo
35 posts in 96 days
#1 posted 09-15-2021 09:56 PM
It looks like the right angle jig that came with my incra router fence. I think it’s for clamping wide boards upright and the whole mess slides along the fence. I don’t use it so that’s a guess. It might be helpful for box joints?
View Madmark2's profile
Madmark2
3098 posts in 1835 days
#2 posted 09-16-2021 12:37 AM
+1, on box joint jig for gang end cuts.
It slides against the fence with multiple pieces clamped vertically. The clue is the runner risers to prevent plowing thru the bass. I made one nearly identical years ago. Do you have an incra router fence to use it with?
-- The hump with the stump and the pump!
StevoWevo
35 posts in 96 days
#3 posted 09-16-2021 10:54 PM
YeahI do Madmark, but I haven’t really done a whole lot of wood working that would take advantage of its capabilities yet. I do love the fine adjusting with the positioner dial and the lift.
Tgobbs
#4 posted 09-20-2021 05:55 PM
Thanks to StevoWevo and Madmark2 for responding. I don’t have an incra router fence so the jig, as I intended it was not for that. I think Madmark2 has the clue, clamping vertical boards and the use of the runner risers. But I am pretty sure it was for the table saw. I’ll keep searching. Maybe come to me in a dream.
Madmark2
#5 posted 09-20-2021 06:16 PM
The jig works on the saw if you have an Incra TS fence. Just more passes or use a dado set.
Tgobbs
#6 posted 09-20-2021 07:53 PM
I should have said I do not have an incra table saw fence. I have a steel city fence and it is too narrow for the jig.
