T Track
Forum topic by Karda posted 09-06-2021 10:13 PM 357 views 0 times favorited 15 replies Add to Favorites Watch
View Karda's profile
Karda
3376 posts in 1795 days
09-06-2021 10:13 PM
hi, i want to make a wedgie sled for cutting segments and am using T track for the adjustment, however I bought one track that is made for .25” hex bolts. can you use .25” hex bolts or .25” carriage bolts with track made for t track bolts
15 replies so far
View JAAune's profile
JAAune
2034 posts in 3558 days
#1 posted 09-06-2021 11:10 PM
Never tried carriage bolts with that t-track before. The track McMaster-Carr sells has a slot opening that is .343” wide so the square part of the carriage bolt would need to match or it wouldn’t work. Also, the head on the carriage bolt would need to be less than 7/16” wide.
My preference is to use 5/16”-18 elevator bolts and cut the flanges to fit. A cut-off wheel on an angle grinder does this quickly but it’s still time consuming to trim and deburr if a lot of bolts are needed. Still, I think it’s worth the effort because the result is a bolt that slides smoothly and doesn’t create burrs on the t-track. 1/4-20 bolt heads tend to hang up on occasion.
(McMaster source here)
-- See my work at http://altaredesign.com
JAAune
#2 posted 09-06-2021 11:16 PM
Looks like you’d need to grind the heads on carriage bolts to use them. The square part on a 5/16”-18 bolt is about right but the head is .719” wide.
McMaster carriage bolts
View splintergroup's profile
splintergroup
5854 posts in 2463 days
#3 posted 09-07-2021 12:11 AM
Toilet flange bolts are also good. Some HW stores sell them separately.
View Lazyman's profile
Lazyman
7948 posts in 2629 days
#4 posted 09-07-2021 12:30 AM
- splintergroup
+1. You will probably just have to cut them to length.
Karda
#5 posted 09-07-2021 02:12 AM
ok thanks
View therealSteveN's profile
therealSteveN
8842 posts in 1815 days
#6 posted 09-07-2021 03:22 AM
- Karda
it depends on the track. I ran into some a long time ago that a toilet bolt fit fine but a 1/4 20 hex wouldn’t quite get in, but most will either do a toilet bolt, or a 1/4- 20 hexhead, unless they are the 3/8-16 variety.
-- Think safe, be safe
Karda
#7 posted 09-07-2021 04:12 AM
ok thanks
View WoodES's profile
WoodES
198 posts in 2932 days
#8 posted 09-07-2021 04:49 AM
You can also order Tee bolts from amazon.
Karda
#9 posted 09-07-2021 04:54 AM
ok
View bondogaposis's profile
bondogaposis
6046 posts in 3592 days
#10 posted 09-07-2021 01:43 PM
Yes, you can just grind the sides off of the carriage bolts. I do it all of the time.
-- Bondo Gaposis
View Robert's profile
Robert
4731 posts in 2722 days
#11 posted 09-07-2021 02:16 PM
T tracks can be aggravating. It seems there are different sizes, for example some take 1/4” hex head bolts, but will not take a regular T track bolt.
IME the toilet bolts will usually fit.
FWIW, the Incra tracks are larger and will take a Festool track saw clamp.
View squazo's profile
squazo
303 posts in 2886 days
#12 posted 09-07-2021 04:00 PM
I can buy square head bolts at my local hardware store
Karda
#13 posted 09-07-2021 04:20 PM
thanks for your suggestions, i ordered a piece that says it takes hex bolts
View WoodenDreams's profile
WoodenDreams
1432 posts in 1152 days
#14 posted 09-07-2021 05:26 PM
I know you just ordered the T-Track. For future reference, this is the type I use, the Rockler Universal T-tracks. It accepts 1/4” & 5/16” T-bolts, and 1/4” hex head bolts. I keep extra on hand in case I need to make a quick jig. https://www.rockler.com/shop?w=t-track
Karda
#15 posted 09-07-2021 05:33 PM
ok thanks
