Forum topic by steambc500 | posted 08-17-2021 11:20 AM | 688 views | 0 times favorited | 6 replies | ![]() |
Hey Guys, I noticed with my Dewalt ROS, it took very little downward pressure to cause the pad to stop visibly spinning. Later, when the speed control pot failed, I bought a Ryobi ROS since I’m invested in the batteries. Again, with this sander, it takes barely any downward pressure at all to stop the pad from spinning. My question is, is the pad supposed to be visibly spinning around for the unit to work, or is the sanding pad still doing its work while the pad appears to be stalled or standing still? Logically it seems that the pad should be spinning, but the reason I question this is that both of my sanders require hardly any pressure at all to stall the spinning. Thanks! -- Brian from Connecticut. Unbiased Tool Reviews at https://www.Tool-Smart.com |
