Bowls with feet and texture
« back to Woodturning forum
Forum topic by Aj2 posted 08-14-2021 03:50 AM 510 views 0 times favorited 15 replies Add to Favorites Watch
View Aj2's profile
Aj2
4072 posts in 3042 days
08-14-2021 03:50 AM
I would like to share with the wood turners here small bowls with feet and texture on the outside.
As you can see the wood is pretty much firewood quality. The big one is about 5 inch across and 3 inches tall.
No sanding inside out. I finish the inside with a negative rake scraper.
It’s my design but feel free to make one or two. They are addicting so be careful :)
Good Luck
-- Aj
15 replies so far
View SMP's profile
SMP
4836 posts in 1150 days
#1 posted 08-14-2021 04:05 AM
Very cool! reminds me of molcajetes from Mexico, only those are usually stone.
View pottz's profile
pottz
20683 posts in 2229 days
#2 posted 08-14-2021 04:31 AM
very cool can you give more detail in the process you use to create these beautiful bowls ? im very interested.
View Aj2's profile
Aj2
#3 posted 08-14-2021 02:42 PM
- pottz
Sure any particular part that you want to hear about.
I don’t want to insult anyone with something that’s obvious. My main goal is to make these without sandpaper inside and out. but that doesn’t mean they couldn’t be sanded smooth.
-- Aj
pottz
#4 posted 08-14-2021 07:57 PM
are the feet attached separately or turned from the same block of wood.
View Aj2's profile
Aj2
#5 posted 08-14-2021 09:30 PM
The same block of wood I turn the outside and bottom first.
Here’s a look at the bottom after it’s been turned on the lathe. The bottom is left thick so my chuck holds tight. I also have this one marked for the position of the feet paying attention to the grain for maximum strength.
-- Aj
pottz
#6 posted 08-14-2021 09:45 PM
- Aj2
thanks aj.
View RyanGi's profile
RyanGi
84 posts in 281 days
#7 posted 08-14-2021 10:12 PM
How did you go about texturing them?
-- Ryan/// I like chips...and sawdust...but mostly chips...with vinegar
View Aj2's profile
Aj2
#8 posted 08-14-2021 11:42 PM
Just regular carving gouges I chase the grain down hill to get clean cuts. It’s a really good way to teach the mind to go with the grain.
Also do a lot of shaping with Nicholson 49 & 50 patten files or rasps.
Good Luck
-- Aj
View Lazyman's profile (online now)
Lazyman
7971 posts in 2632 days
#9 posted 08-14-2021 11:47 PM
I’ve been meaning to try turning something with feet like that. Very nicely done. I assume you added the bow tie on the cracked one before turning?
View Aj2's profile
Aj2
#10 posted 08-15-2021 01:34 AM
- Lazyman
The bows I added afterwards there’s 2more on the bottom. The wood is eucalyptus and it incredibly tough. The bow ties are mostly for visual interest.
I’m ramping up to do a craft show next month and another before the holidays.
Trying to anticipate what will sell is a lot like voodoo :)
-- Aj
Lazyman
#11 posted 08-15-2021 03:18 AM
I don’t sell my stuff but I find that colored epoxy or turquoise in cracks and worm holes really seems to catch people”s eye. I have even used brass powder and epoxy which polishes like solid brass. When I give stuff to my friends, that is usually what they gravitate towards. Another that they seem to like are live edged bowls.
118258 posts in 4821 days
#12 posted 08-15-2021 10:05 PM
Very cool I like the feet and texturing a lot.
View Aj2's profile
Aj2
#13 posted 08-15-2021 11:53 PM
Thanks Jim.
-- Aj
View MrUnix's profile
MrUnix
8773 posts in 3443 days
#14 posted 08-16-2021 01:05 AM
Cool design… what do you use to cut the feet out… or I should say, to cut the non-feet portions out ;)
View Aj2's profile
Aj2
#15 posted 08-16-2021 01:36 AM
- MrUnix
I use a handsaw and make a cut on each side or the feet to the other side. Then a chisel to break out the chunks of short grain wood.
As I mentioned above I use a no50 &49 rasp to shape everything better texturing.
-- Aj
