Holdfasts....how many?
« back to Hand Tools forum
Forum topic by Chairmaker14 posted 08-09-2021 10:28 AM 1024 views 0 times favorited 43 replies Add to Favorites Watch
View Chairmaker14's profile
Chairmaker14
15 posts in 1767 days
08-09-2021 10:28 AM
Topic tags/keywords: holdfast gramercy holdfasts workbench clamps
How many holdfasts should one have for your workbench? Can you get by with 2, or should one have 3 or 4 or more?
43 replies so far
View SMP's profile
SMP
4840 posts in 1152 days
#1 posted 08-09-2021 01:06 PM
really depends on what you are making and how many other vises and clamps you have, and the design of your bench. I have 2 but usually only use 1.
View Robert's profile
Robert
4744 posts in 2727 days
#2 posted 08-09-2021 01:17 PM
If you mean bench hooks, as many as you need.
I have one and pretty much only use it for chopping dovetails.
Don’t drill any holes until you start working, then figure the optimal location(s).
View Tony1212's profile
Tony1212
608 posts in 2981 days
#3 posted 08-09-2021 01:26 PM
I have two. I usually only use one at a time, but I’ve used both for longer pieces that can rotate around a single clamp point. I also have a face vise and bench dogs to help hold things in place.
If you have holes in the bench for holdfasts, you can use them for bench dogs. In that case, I think 2 would be plenty. But I’m sure you will run into a case, once every 10 years, where having a third holdfast would be beneficial.
You can just buy one and once you’ve used it for awhile, buy more if you find that you need them.
-- Tony, SW Chicago Suburbs
View Lazyman's profile (online now)
Lazyman
7990 posts in 2633 days
#4 posted 08-09-2021 01:34 PM
A lot of people don’t use them at all and simply use dogs, hooks and stops in ways that allow them to not need them. Probably 90% of the time you will only need one but a second will help when you are working on a piece that is badly warped so that the dogs don’t work well. I think it would be very rare that you need more than 2 and you could probably just pull out a clamp in that rare occasion and clamp along the edge of the bench for a particularly difficult and large board.
Smitty_Cabinetshop
17534 posts in 3864 days
#5 posted 08-09-2021 02:34 PM
I have three… two of the ‘whack them’ types and one that is the veritas hold-fast.
I don’t recall ever using all three at the same time, but I do think having to veritas tool is a great option to have at times.
-- Don't anthropomorphize your handplanes. They hate it when you do that. - OldTools Archive -
View theoldfart's profile
theoldfart
12870 posts in 3697 days
#6 posted 08-09-2021 03:03 PM
I have two and use both frequently.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Chairmaker14
#7 posted 08-09-2021 03:05 PM
Thanks for all the great replies. There seems to be a shortage. I managed to find one holdfast, but with a 3/4” shaft which apparently means I need 1” holes. I’ll go with the advice on not drilling til I figure out where I need one.
View HokieKen's profile (online now)
HokieKen
19393 posts in 2384 days
#8 posted 08-09-2021 03:13 PM
I have two and use them together often. I have specialty vises and tools like miter saws that are mounted on boards. I set them on the bench and use both holdfasts to hold them in place and prevent rotation. Of course there are many ways to skin a cat and I could use bench hooks instead. It’s just easier to store stuff for me when it sits flat.
Basically it boils down to one holdfasts can hold most things down but you need a second constraint, a second holdfast or a hook or dog etc. etc., to prevent it from rotating as well.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View SMP's profile
SMP
#9 posted 08-09-2021 03:30 PM
Thanks for all the great replies. There seems to be a shortage. I managed to find one holdfast, but with a 3/4” shaft which apparently means I need 1” holes. I ll go with the advice on not drilling til I figure out where I need one.
- Chairmaker14
there may be a shortage of the nae brand makers. but if you look on Etsy plenty of blacksmiths there sell them. its basically a bent piece of 3/4” steel bar, so doesn’t need any special skill really.
as for placement, Chris Schwarz offers some good recommendations in his Anarchist Workbench book. the pdf is free and searchable.
View controlfreak's profile
controlfreak
2908 posts in 847 days
#10 posted 08-09-2021 05:04 PM
I bought two of the iron ones made and sold on Amazon but never got a good bite. I bought two from Gramercy and after roughing up the shafts a bit, love’em. I often use two but never found myself wishing for a third….yet. I placed one row of 3/4” holes in the bench that line up with the wagon vise and planed to add more when needed but never found the need yet. The holes accept both bench dogs and holdfasts.
View Johnny7's profile
Johnny7
692 posts in 2336 days
#11 posted 08-09-2021 05:10 PM
2 hold fasts and a “doe’s foot”
View Thedustydutchman's profile (online now)
Thedustydutchman
84 posts in 153 days
#12 posted 08-09-2021 05:14 PM
I started with one and only drilled the holes as I needed them. I just ordered a second this weekend. I got mine from a guy on ebay out of New Mexico. Very nice blacksmith made and used a file to rough up the shaft and they work beautifully.
Oh and a doe’s foot is a PERFECT addition to the holdfast.
-- Jerry H - Holland Michigan
Chairmaker14
#13 posted 08-09-2021 05:21 PM
Jerry H.
Can you post the blacksmiths name?
- Thedustydutchman
Chairmaker14
#14 posted 08-09-2021 05:22 PM
Thank you, never knew what a “does foot” was til today.
2 hold fasts and a “doe s foot”
- Johnny7
View gtrgeo's profile
gtrgeo
191 posts in 1676 days
#15 posted 08-09-2021 09:36 PM
I can’t speak for the the dustydutchman but I believe these may be the ones he is referring to. I believe this guy sells on both Amazon and Etsy.
showing 1 through 15 of 43 replies
