Forum topic by fredringwald | posted 08-09-2021 10:07 AM | 777 views | 0 times favorited | 6 replies | ![]() |
Hello, I just purchased a Delta 50-904 dust collector with a cracked impeller. The impeller is about 15 pounds of cast aluminum with straight fins that are about 5 inches long. I am very concerned that a weld repair might not be adequate and that trying to spin the repaired impeller might cause it to come apart and create a very real safety hazard in my shop. What do you think? It would also cost me about $600 to get this impeller repaired and re-balanced. Alternatively, I would be very happy to buy another impeller to replace it. However, I am not finding success in locating an affordable replacement. I found three sources for identical OEM replacements, with prices of $1240, $2500, and $3600, respectively. The 7.5 hp motor shaft is 1 1/8 inches in diameter, and the impeller is 16 inches in diameter. I would be content with a smaller impeller if I could mount it to this motor. i welcome any recommendations! Thank you! Fred Ringwald |
