Walnut end grain cutting board
Forum topic by Jeppedy posted 08-08-2021 03:49 AM 901 views 0 times favorited 16 replies Add to Favorites Watch
View Jeppedy's profile
Jeppedy
10 posts in 2614 days
08-08-2021 03:49 AM
Topic tags/keywords: end grain cutting board walnut
Starting my first end-grain cutting board, walnut and maple. “Planed” flat with a router jig. Sanding now, and the grain of walnut looks like those pore will never close up or sand smooth.
If I keep sanding, will they smooth out eventually?
Do I need a sanding sealer? Pore filler?
Any advice appreciated!
-- Jeff, Newbie from Northwest Indiana
16 replies so far
View therealSteveN's profile
therealSteveN
8828 posts in 1813 days
#1 posted 08-08-2021 06:40 AM
How are you sanding, and what grit progression are you doing? Routing end grain with a planer bit might fur things up, as much as calm them down. I don’t think I would suggest that, now on face grain it can level you pretty well.
-- Think safe, be safe
View LittleBlackDuck's profile (online now)
LittleBlackDuck
8083 posts in 2059 days
#2 posted 08-08-2021 10:14 AM
I think those holes you have are far too big. The gap between the two layers will never be sealed.
View Rich's profile (online now)
Rich
7442 posts in 1828 days
#3 posted 08-08-2021 01:42 PM
As someone who has used a router sled many times, I can assure you that it is an ideal method to flatten an end grain board. Any suggestion otherwise is misguided and should be ignored.
Walnut is an ideal wood for cutting boards, but without seeing yours I can’t comment on your specific situation. However, I’ve never seen walnut that’s too porous for an end grain chopping block.
One thing I can say is that you should not use any sort of sanding sealer or filler, but beyond that, you don’t provide enough detail for me to go on.
View Tony1212's profile
Tony1212
594 posts in 2973 days
#4 posted 08-20-2021 12:42 PM
Might be wiser to ignore your advice.
A router and sled are only ideal if all you have is a router.
More ideal for some of us is a widebelt sander.
For others, a cnc is a better choice.
- xedos
Since the OP says it is their first end grain cutting board, it’s probably safe to assume they are fairly new to the hobby and probably don’t have a widebelt sander or a drum sander readily available. But they obviously have a router. Therefore, a router sled would be ideal in that case.
And isn’t a router sled just a manual CNC machine (as it pertains to flattening)?
As for the OP, we need pics to better help figure out the best possible solutions.
-- Tony, SW Chicago Suburbs
View HokieKen's profile
HokieKen
19343 posts in 2377 days
#5 posted 08-20-2021 05:13 PM
I’ve used a router sled to flatten end grain cutting boards. It worked just fine. Would a wide belt sander be better? Sure. If you have access to one, by all means use it. CNC? Seems like the results would be identical to a router sled assuming you have straight guide rails.
Not sure why your Walnut would have such open endgrain. Never had a problem with it myself. Some pics showing exactly what you’re referring to would let us offer better suggestions. I guess the first question that comes to mind is: Are you positive it’s Walnut?
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
HokieKen
#6 posted 08-20-2021 05:17 PM
And I hate to address this but I will anyway…
There is a very big difference between saying:
...it is an ideal method to flatten an end grain board. ...
- Rich
and saying:
Assuring people that you have the ideal method to flatten an end grain board …
- xedos
Ugh fellas.
View LeeRoyMan's profile
LeeRoyMan
2147 posts in 965 days
#7 posted 08-21-2021 03:40 PM
- xedos
LOL, kinda the same thing as me posting an air sander right?
Look up hypocrite in the dictionary.
View toolie's profile
toolie
2210 posts in 3867 days
#8 posted 08-21-2021 03:48 PM
Where’d the OP go?
View Andre's profile
Andre
4733 posts in 3045 days
#9 posted 08-21-2021 04:05 PM
Where d the OP go?
- toolie
LOL! Yup, shaking his head and quickly realized when you ask for free advice, ya get what ya pay for:)
Projects posted usually clears thing up for me!
View xedos's profile
xedos
433 posts in 539 days
#10 posted 09-01-2021 02:09 AM
- LeeRoyMan
Sorry bud, not like your sander comment. Ric got on his soapbox and said the ideal way is with a router and every other way was misguided because he thinks he’s the ultimate authority on flattening endgrain. I was not responding to the o.p. at all.
Rich
#11 posted 09-01-2021 03:15 AM
- xedos
Somebody’s got a fixation. If only you could differentiate between “an ideal,” and “the ideal.”
This is more sad than funny.
View bigblockyeti's profile
bigblockyeti
7611 posts in 2959 days
#12 posted 09-01-2021 10:22 AM
I usually start first with gluing everything up so it starts as flat as possible greatly reducing how much the surface needs to be flattened. I don’t use a router else because I’m starting close to as flat as I would get after finishing using a router sled. I start with a belt sander, usually 40 or 60 grit, starting with 40 grit is usually less than 20 seconds per side, after progressively graduating to 120 grit with a belt sander then I switch over to a ROS and progress through 240 grit. Starting with a belt sander is far faster that even the best ROS initially.
LittleBlackDuck
#13 posted 09-01-2021 11:13 AM
... Starting with a belt sander is far faster that even the best ROS initially.
- bigblockyeti
Looks like I know someone that hasn’t used a Rotex!
HokieKen
#14 posted 09-01-2021 12:12 PM
Make that two of us that haven’t used a Rotex LBD ;-)
I will add that I made some endgrain boards as Christmas gifts last year. And what worked best for me to do final flattening was my Veritas Low Angle Jack Plane. With the caveat that you have to dub the edges first to avoid tearout on the ends. And I realize that hand planes aren’t for everyone. I’m not the guy who tells you if you use power tools you’re doing it wrong. I love my electron-eaters :-) But it did work quite the trick for me so I thought I’d throw it into the mix.
bigblockyeti
#15 posted 09-01-2021 03:10 PM
- bigblockyeti
Looks like I know someone that hasn t used a Rotex!
- LittleBlackDuck
I have, I was contemplating the big one before the Festool PRO 5 LTD went on sale for $100 a few years ago, so got that. The Rotex was impressive, just not impressive enough for me. Grit for grit a 4×24 has a far greater surface speed than a Rotex, close to the same surface area and 99% of 4×24 belt sanders available have more powerful than any Rotex.
