Hidden Hinges
Forum topic by PapaP posted 08-01-2021 02:03 PM 283 views 0 times favorited 6 replies Add to Favorites Watch
View PapaP's profile
PapaP
26 posts in 219 days
08-01-2021 02:03 PM
Hello and good morning.
I have a situation where a customer REALLY wants European style hidden hinges but the face frames are plywood. The cabinets were built in 1977 with oak plywood. I’m wondering if I drill a pilot hole and put a little bit longer screws in the ply with maybe a little wood glue on each screw if it would work out. Anyone ever try this method? Any other suggestions?
-- PapaP
View Phil32's profile
Phil32
1558 posts in 1115 days
#1 posted 08-01-2021 03:03 PM
How can anyone answer your question without knowing dimensions? Plywood thickness? A photo would help.
-- You know, this site doesn't require woodworking skills, but you should know how to write.
PapaP
#2 posted 08-01-2021 03:23 PM
3/4 oak plywood face.
The largest door is 18” x 22”
The new doors will be shaker style with poplar rails and stiles.
1/4 birch/mdf core for the panel.
-- PapaP
PapaP
#3 posted 08-01-2021 03:31 PM
-- PapaP
View Axis39's profile
Axis39
536 posts in 809 days
#4 posted 08-01-2021 03:56 PM
You could get the frameless style and attach blocks to the backs of the face frames. I’ve done this in the past.
-- John F. SoCal transplant, chewer uppper of good wood
View 1thumb's profile
1thumb
502 posts in 3368 days
#5 posted 08-01-2021 04:46 PM
Pre drill w/smaller diameter bit and you should be fine. Have done many piano hinges like that. Or, tell customer of your concerns, charge more to glue, brad and clamp 3/4 wood rips to face frame then hinges.
-- “Some say it's just a part of it. We've got to fulfill the book.”
PapaP
#6 posted 08-01-2021 05:27 PM
Both great ideas. Thank you.
-- PapaP
