Identifying Wood
Forum topic by Woodyvolt posted 07-11-2021 06:19 PM 579 views 0 times favorited 27 replies Add to Favorites Watch
View Woodyvolt's profile
Woodyvolt
81 posts in 1407 days
07-11-2021 06:19 PM
Need assistance ID’ing this wood.
27 replies so far
Woodyvolt
#1 posted 07-11-2021 06:21 PM
Same wood with mineral oil wipe
Woodyvolt
#2 posted 07-11-2021 06:22 PM
End grain of last post
View SMP's profile
SMP
4840 posts in 1151 days
#3 posted 07-11-2021 06:38 PM
does it have any noticable smell when cut fresh?
View splintergroup's profile
splintergroup
5877 posts in 2468 days
#4 posted 07-11-2021 06:52 PM
Bubinga popped into my head at first glance.
View Rich's profile
Rich
7466 posts in 1835 days
#5 posted 07-11-2021 07:30 PM
I’m gonna toss chechen out there.
View DevinT's profile
DevinT
1942 posts in 212 days
#6 posted 07-11-2021 07:38 PM
Looks like Bocote
-- Devin, SF, CA
View Phil32's profile
Phil32
1587 posts in 1149 days
#7 posted 07-11-2021 07:38 PM
If all you get from responders are random guesses with no reference to authoritative sources, how (and why) would you use the results? It doesn’t help to have a name for the wood if you cannot be sure it’s accurate.
-- You know, this site doesn't require woodworking skills, but you should know how to write.
DevinT
#8 posted 07-11-2021 07:44 PM
Ummm, OK?
It looks like Bocote because of the grain pattern looks exactly like the Bocote I have in my garage. But if you need me to take a picture, I will.
It’s not a random guess. It looks exactly like Bocote.
One person asked if it had a smell. That’s probably because Bocote has a distinct smell. Some say it smells like dill pickles. I just think it smells nice.
The weight will be the biggest give away for Bocote. Another dead give away would be the way it ages. I have a piece of aged Bocote I can share too.
The face grain, edge grain, and long grain all looks like Bocote, but go ahead and call it a random guess.
-- Devin, SF, CA
DevinT
#9 posted 07-11-2021 07:46 PM
You might also think about photographing it under black light since that is a valid method of identifying some similar looking species. Some fluoresce while others do not.
-- Devin, SF, CA
View CaptainKlutz's profile (online now)
CaptainKlutz
4905 posts in 2740 days
#10 posted 07-11-2021 07:46 PM
The color difference between photos makes this one difficult.
Does it have orange tones, or is it brown/black?
Regardless, could be from Fabaceae genus
Maybe one of the many true Rosewoods, or from Acacia or Wattle genus?
This might help:
https://www.wood-database.com/wood-articles/distinguishing-brazilian-rosewood-from-east-indian-and-other-rosewoods/
IMHO – need a 10x magnification of end grain to help with ID. Measuring density, and checking florescence would help ID too.
If not from Fabaceae, then suggest one of the look a likes:
Pau Ferro,
Bocote (smells like pickles)
Chechen
Macacauba
When I need help identifying wood, these are my primary references:
http://www.hobbithouseinc.com/personal/woodpics/
https://www.wood-database.com/wood-finder/
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
Woodyvolt
#11 posted 07-11-2021 08:13 PM
Thanks for the reply’s. After comparing the wood to the suggested types, I found that Bocote is by far the best match. However, it doesn’t have a distinctive smell and probably has about the same weight as oak.
I realize that it is hard to pin point exact types with pictures; I will just make my project with the hope that it turns out satisfactory.
View Rich's profile
Rich
#12 posted 07-11-2021 09:12 PM
If all you get from responders are random guesses with no reference to authoritative sources, how (and why) would you use the results? It doesn t help to have a name for the wood if you cannot be sure it s accurate.
- Phil32
Speak for yourself, Phil. Maybe your guesses are random, but mine are educated ones.
View Rich's profile
Rich
#13 posted 07-11-2021 09:19 PM
Thanks for the reply s. After comparing the wood to the suggested types, I found that Bocote is by far the best match. However, it doesn t have a distinctive smell and probably has about the same weight as oak.
- Woodyvolt
Bocote is a reasonable possibility as well. It and chechen are heavier than oak, with chechen being the heaviest.
It’s a beautiful piece of wood either way. What are you planning to build with it?
View LeeRoyMan's profile
LeeRoyMan
2159 posts in 973 days
#14 posted 07-11-2021 09:25 PM
No doubt, it’s teakabolo…
(that or Chinese ash)
View SMP's profile
SMP
#15 posted 07-11-2021 09:34 PM
- Phil32
- Rich
Majority of his posts are condescending to other posters’ opinions, which is ironic because the whole point of forums is to get other people’s opinions.
