Digital caliper
« back to Hand Tools forum
Forum topic by Ken Olsen posted 07-05-2021 11:34 PM 740 views 0 times favorited 12 replies Add to Favorites Watch
View Ken Olsen's profile
Ken Olsen
37 posts in 597 days
07-05-2021 11:34 PM
Does anyone know where I can find a electronic digital caliper that only goes down to 1/16 or 1/32. I have one that I use for woodworking and turning, the problem is it says in 9/232. And if I try to adjust it to say 3/4 inch when. Turning it’s so hard to get it to 3/4 any suggestions would be appreciated
-- My daughter came into the garge when she was small and said I know what your making mom told me Its a Mess
12 replies so far
View Barkley's profile
Barkley
114 posts in 1053 days
#1 posted 07-05-2021 11:42 PM
Check out Stumpy Nubs website. Seems like he found some that were for woodworkers.
-- Thin the herd
View Richard Lee's profile
Richard Lee
510 posts in 2226 days
#2 posted 07-06-2021 12:51 AM
View tvrgeek's profile
tvrgeek
2375 posts in 3100 days
#3 posted 07-06-2021 01:06 AM
Do the work up front and learn to dump fractions. Go to decimal or metric. You won’t have that problem any more.
View donald_wa's profile
donald_wa
23 posts in 2544 days
#4 posted 07-06-2021 02:27 AM
You don’t really need a fancy digital caliper for wood. If you need a 3/4 inch tenon, use a 3/4 ” open end wrench .
View CaptainKlutz's profile (online now)
CaptainKlutz
5579 posts in 2946 days
#5 posted 07-06-2021 02:35 AM
iGaging offers one, PN 100-333-8. Sold many places.
BORG offers several online, General Tools PN 1478 and a Husky model. The call them 3-mode calipers. The General set I used would read down to 64ths in fractional mode.
For lathe work: why not use regular turning caliper; and keep a 3/4” thick reference block around for repeatable setting?
Cheers!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
View MPython's profile
MPython
426 posts in 1264 days
#6 posted 07-06-2021 03:23 AM
I have a fractional dial caliper that is the mainstay of my layout tools. I like it much better than the digital ones because I can tell at a glance whether 11/32 is greater or less than 3/8 without doing any math in my head.
View SMP's profile
SMP
5296 posts in 1357 days
#7 posted 07-06-2021 05:24 AM
- MPython
same, i have a fractional dial caliper from HF and love it. and i don’t need to worry about the batteries being dead when i need it or batteries leaking and destroying the tool.
View AlaskaGuy's profile
AlaskaGuy
6871 posts in 3760 days
#8 posted 07-06-2021 07:16 AM
https://youtu.be/-NyPGbWBr30
tvrgeek
#9 posted 07-06-2021 08:05 AM
If you only need accuracy to 1/32 or so, just use the simple Taytools thickness gauge. I was able to tweak it to be quite accurate. Sits on top of my planer.
View controlfreak's profile
controlfreak
3706 posts in 1053 days
#10 posted 07-06-2021 10:31 AM
- SMP
This was my thought process and went to pick up a dial version because I was tired of dead batteries. Someone had put the dial sleeve on another digital one so now I have two. I gave up and bought a sleeve of ten batteries.
Ken Olsen
#11 posted 07-06-2021 08:48 PM
Thanks for all the GREAT replies i am lucky if i can cut a piece of wood down to 1/8 but i really like to us it when thinness planning I think ill take the suggestion and dump my digital scale and get a old style dial
great site for answers to all questions
View OSU55's profile
OSU55
3034 posts in 3441 days
#12 posted 01-24-2022 01:17 PM
You don t really need a fancy digital caliper for wood. If you need a 3/4 inch tenon, use a 3/4 ” open end wrench .
- donald_wa
That will not fit into a 3/4” drilled hole without a big hammer. Sharpened Open end wrenches work great but are oversized to fit nut/bolt flats. Soft wood ok, hard wood gotta trim.
