Looking for a 1-1/4" x 8 TPI reversible chuck
« back to Woodturning forum
Forum topic by bobasaurus posted 06-20-2021 07:26 PM 691 views 0 times favorited 23 replies Add to Favorites Watch
View bobasaurus's profile
bobasaurus
3733 posts in 4342 days
06-20-2021 07:26 PM
I’m about to receive a new G0733 wood lathe and am looking into chuck options. It’s reversible and has a 1-1/4” x 8 TPI spindle. I can’t seem to find a reversible chuck that supports this spindle threading, looking for recommendations.
The chuck I’ve been using on my old lathe is a PSI Barracuda (CSC3000C), and I have an adapter to make it fit the new 1-1/4”x8 spindle but it’s not reversible.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
23 replies so far
View Dave Polaschek's profile
Dave Polaschek
7954 posts in 1741 days
#1 posted 06-20-2021 07:53 PM
Pretty sure there’s a Nova G3 Pro-Tek with those options. Call Teknatool and they’ll tell you for sure. I don’t recall whether there’s an adapter in the mix or not, as I have 1×8 threads on my Harbor Freight midi.
-- Dave - Santa Fe
View MrWolfe's profile
MrWolfe
1649 posts in 1282 days
#2 posted 06-20-2021 08:37 PM
The SuperNova bundles have the reverse turning set screw. They also have dovetailed 50mm jaws. The Nova 23108 Premier Pro-Tek Supernova 2 Chuck Bundle with Pro-Tek 2” Jaw Set is the set I bought that has them. I had to specify the 1 1/4×8 tpi adapter for the chuck. They are not inexpensive but no regrets here especially with the dovetailed 50mm jaws.
bobasaurus
#3 posted 06-20-2021 08:42 PM
Interesting options, thanks. None of them come direct threaded for 1-1/4×8 tpi, but it looks like it might be an option on the “insert thread” models. Is it better to get an insert thread for 1-1/4×8 tpi, or use an external adapter on the 1×8 tpi direct threaded chuck?
View GR8HUNTER's profile
GR8HUNTER
8610 posts in 1871 days
#4 posted 06-20-2021 08:43 PM
WOULD THIS WORK Allen ? :<)))
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
bobasaurus
#5 posted 06-20-2021 08:47 PM
- MrWolfe
The options on the nova “pro-tek” page are:
48290 NOVA PRO-TEK G3 INSERT THREAD CHUCK & JAWS
48291 NOVA PRO-TEK G3 DIRECT THREAD 1″X8TPI REVERSIBLE CHUCK & JAWS
48293 NOVA PRO-TEK G3 DIRECT THREAD 1″X8TPI REVERSIBLE CHUCK BUNDLE
23108 NOVA PRO-TEK SUPERNOVA2 INSERT CHUCK BUNDLE
23262 NOVA PRO-TEK SUPERNOVA2 INSERT CHUCK & JAWS
Based on the description, it looks like only the “G3” model has reversible options.
bobasaurus
#6 posted 06-20-2021 08:48 PM
Thanks Tony, that’s an interesting alternative. Would have to get a vacuum chuck though.
MrWolfe
#7 posted 06-20-2021 08:51 PM
The external adapter may add a bit of run out as it will add some lenth to the chuck assembly. That means it will shorten your center to center length. The Nova 23108 Premier Pro-Tek Supernova 2 Chuck Bundle is reversible, it has a grub screw/set screw that secures it to the spindle. I wanted a direct thread chuck but the Supernova has been great.
bobasaurus
#8 posted 06-20-2021 09:03 PM
Thanks for the info, wanted to make sure the model was correct. Wish their website had this information listed, or even just some better pictures. Might order the 23108 since I don’t want to deal with run-out as you say. Does it come with several inserts, or do you need to order a specific insert for your spindle threading?
Dave Polaschek
#9 posted 06-20-2021 09:06 PM
I have a supernova 2 and a G3. I prefer the G3, as it seems to hold better. The SuperNova creeps a little on me, but that may just be that it needs a rebuild (I bought it used).
-- Dave - Santa Fe
MrWolfe
#10 posted 06-20-2021 09:08 PM
In that bundled set you select the size insert you want for your particular lathe.
I ordered mine on Amazon from the Nova store.
https://www.amazon.com/Nova-Premier-Supernova-Woodworm-accessories/dp/B08M93X8S9?dchild=1
View bigJohninvegas's profile
bigJohninvegas
1063 posts in 2620 days
#11 posted 06-21-2021 03:20 AM
The Oneway chucks also have a set screw to lock them on for reverse turning. I have both a Talon, and a Stronghold chuck.
https://www.woodturnerscatalog.com/t/189/Chuck-Accessories
Looking at the adapter for vicmarc chucks, they look to have the set screw hole too.
-- John
View WoodenDreams's profile
WoodenDreams
1351 posts in 1069 days
#12 posted 06-21-2021 03:23 AM
Tecknatool has the Nova Infinity Chucks and jaws on sale for 30% off, thru June 21st. I was on their site today and order some stuff. I could not see if they have 1 1/4×8 option . Tecknatool.com
bobasaurus
#13 posted 06-21-2021 04:12 AM
Are any of these chucks not Chinese-made? Would love to have a German or US one, despite the premium price.
Edit:
Nova: unclear origin, may be Chinese or from NZ
Vicmarc: made in Australia
Oneway: made in Canada
View Woodmaster1's profile
Woodmaster1
1787 posts in 3745 days
#14 posted 06-21-2021 07:47 AM
I have the Oneway stronghold and talon chucks great lathe chucks. I use the supernova at my woodworking club shop sometimes but use my own most of the time at the club shop. The supernova because of the use it gets at the club shop needs repaired occasionally due to the high use.
bigJohninvegas
#15 posted 06-23-2021 02:45 AM
Edit:
- bobasaurus
So I found the same info on country of origin for Vicmarc and Oneway. but did not see anything on Teknatool web site.
So funny, just now I was taking some photos of my chucks to show what they use for a set screw to lock them for reverse turning. and noticed my Supernova 2 chuck says made in New Zealand on the back of it.
Here are photos of the chucks showing the set screw location on the adapter.
I have only ever used this on the Oneway Stronghold chuck. Not a feature I use much.
The Supernova is my newest chuck. $50 craigslist find a few months back, I could not pass on. and never compared the adapter to the Oneway chucks before, but the set screw is very small on the nova.
And the Oneway can accept two set screws.
These are all 1-1/4”x8 chucks. the two on the bottom are Oneway Stronghold, and a Talon chuck.
Top is the Supernova 2
This last photo left to right, has the Stronghold, Supernova,and a Vicmarc VM100 clone I got from Grizzly. My 1st chuck, and it has no set screw option. Not sure about a real Vicmarc.
The purpose of this photo is to show the jaws. I have only had the Supernova a few months, and the jaws came with it. they have a dovetail, but notice how thin they are compared to the other two. I have not had a problem with this. And the chuck runs true. Just a little surprised at how thin they are.
So a question for the group, are all the Supernova jaws this thin? or is there something special about this set?
Bob, I hope all the info helps you out,
Good luck.
-- John
